Why a lighter flywheel? - Ducati.ms - The Ultimate Ducati Forum
Old Nov 6th, 2008, 9:24 am   #1 (permalink)
Caidly's Avatar
Post Why a lighter flywheel?
Lost in the other thread, so I'll just ask in a new one...
Anyone care to explain the benefits and disadvantages of a lighter flywheel.
I am sure the brilliant minds at Ducati Engineering came up with the stock weight for a reason. I get the faster spin-up, but what are you trading off? Torque?
if you need to know... ask...
Old Nov 6th, 2008, 9:40 am   #2 (permalink)
johnchypermotard's Avatar
have not had my second cup of coffee yet, so here is a start of the lists ...
benefits of lighter than stock flywheel:
  • provides faster spin-up of engine, so can produce torque and horse power faster
  • produces less gyroscopic effect (due to less rotational mass), which makes the bike drop into and pull out of turns with less effort
reason ducati manufactures with heavier flywheel:
  • engine idles smoother
  • is easier for rider to move from standing stop (more engine rotational weight)
Old Nov 6th, 2008, 10:59 am   #3 (permalink)
Paewraul's Avatar
The key factor is quicker revs. The rotational mass of the flywheel is fairly small, and I don't think turn in is effected....not enough to make a noticable difference.
The biggest change you'll notice is that egine breaking is reduced since less energy is stored in the flywheel due to the lower weight.
2000 748S
2008 HM1100S
Paewraul is offline   Reply With Quote
Old Nov 6th, 2008, 12:34 pm   #4 (permalink)
MarksFriggin's Avatar
Wouldn't engine braking be increased with a lighter flywheel since there's less mass to keep the engine spinning?
Old Nov 6th, 2008, 12:45 pm   #5 (permalink)
corse_ducati's Avatar
Extreme Power wheely's........
corse_ducati is online now   Reply With Quote
Old Nov 6th, 2008, 12:49 pm   #6 (permalink)
yes ... good catch.
forgot to mention that earlier (now have had second espresso)
a heavier flywheel smoothes out power delivery and engine braking effect, as there is more inertia.
Old Nov 6th, 2008, 2:02 pm   #7 (permalink)
kingsnake1650's Avatar
engine braking in theory might be increased..... but since putting the nichols flywheel on I seem to have less wheel hop when hard engine breaking.
kingsnake1650 is offline   Reply With Quote
Old Nov 6th, 2008, 2:20 pm   #8 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
If much of your ride involves stop n' go city street/traffic or sketchy roads you may be better off leaving it stock as the heavier flywheel is smoother.
As with most mods, its a tradeoff. I did notice easier turn-in. I like the quicker engine response, especially with the 15/44 gearing. It does require a little more throttle control when traction is limited however.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Nov 6th, 2008, 3:18 pm   #9 (permalink)
sure ... but your hypertard's engine is putting out about 1500 hp on nitro now, right?
Old Nov 6th, 2008, 4:47 pm   #10 (permalink)
scooter's Avatar
Since the engines are so similar and since this topic was discussed to death on the SC forum, check out this thread:
flywheel, cams or pistons
and this link:
http://www.duc.bz/DUC_Tests_NicholsFlywheel.htm
Also, Dietrich has a fairly recent thread in the SC forum that's devoted to his project of lightening a stock flywheel. Good stuff!
Andy
08 Hypermotard S (red)
07 GT1000 (gray), traded for Hypermotard
06 Genuine Buddy 125
04 Aprilia 50cc 2 stroke, 65 cc cylinder head, touring exhaust, RIP
Custom road bike, Ciocc steel frame, campy road set
scooter is offline   Reply With Quote
Lightweight Flywheel - Pros and Cons Shazaam Hall of Wisdom 30 Dec 13th, 2010 9:24 am
Lighter Flywheel for 1098 Italianbllr3 Superbikes 0 Oct 6th, 2008 12:40 pm
Lighter Flywheel and 520 chain breakdown HyperMotard 10 Jul 10th, 2008 10:52 pm
What do you guys think about upgrading flywheels? S4one Superbikes 37 Feb 5th, 2007 12:42 pm
Benefits of lighter flywheel brianmdavis Superbikes 4 Mar 1st, 2006 12:32 am
