Handlebar clamps question... - Ducati.ms - The Ultimate Ducati Forum
Old Nov 5th, 2008, 6:29 am   #1 (permalink)
johnnymotocros's Avatar
The HB clamps are rubber mounted on the upper triple clamp, and on my bike, one of the rubber mounts is about 1/16" higher than the other, so the HB is not even and looks/feel a bit funny.
The dealer says that the rubber mounts are pressure mounted on the upper clamp and can not be adjusted. They told me they will contact Ducati for advise on what to do, but that was two weeks ago.
Anybody ever removed the clamps or the mounts ?
Any advice ?
johnnymotocros is offline   Reply With Quote
Old Nov 5th, 2008, 8:33 am   #2 (permalink)
kingsnake1650's Avatar
you could probably tighten the higher side and pull it down. The bolt in under the top tripple.
kingsnake1650 is offline   Reply With Quote
Old Feb 1st, 2009, 7:24 pm   #3 (permalink)
Caidly's Avatar
This help?
Did you touch this yet?
if you need to know... ask...
GT1000 vs Sport 1000 - differences and handlebar question axismotorrad Sport Classic 41 Apr 1st, 2010 9:18 am
Fuel filter hose clamps on 999 gnuoyfj Superbikes 6 Jan 12th, 2008 10:46 pm
Handlebar question 99+ SS scooterqualified Supersport 3 Dec 12th, 2007 11:02 am
Slipper clutch installation question dutchduc900 Superbikes 7 May 19th, 2007 12:49 am
Removing handlebar assembly? And, levers number9 Supersport 5 Sep 7th, 2006 8:18 am
