Trying to figure out where the plug interface on the bike is. Seems like the plug is near the battery on most Ducati's. Where is it on the HM? My manual isn't real clear on it.
Can you modify the O2 voltage output with the VDST same as my 02 sensor manipulator does? My TechnoResearch info on the tool doesn't say much about any adjustment capabilities.
Thanks in advance!
the plug for vsdt is located under the riders right side tank cover ... behind the ECU.
The plug is on the right hand side beneath your ECU.
You can't alter the o2 sensor output with the VDST, resetting your TPS and and trimming your fuel is all you can change and you must have the DP ECU as your factory ECU will not take any changes other than your TPS.
