Zard VS Arrow:collectors only - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Motorcycle.com Classifieds!
Old Nov 3rd, 2008, 12:01 pm   #1 (permalink)
Question Zard VS Arrow:collectors only
Apologies for another exhausting thread, but I've searched and didn't find anything relating to my specific question.
Just picked up a DP full system ECU and currently only plan on replacing the header/collector pipes and sticking with the stock cans, having a tuff time justifying $900(+/-) for slip ons that provide at most minimal gains(other than weight savings).
Trying to decide between the Zard or Arrow collectors, price is a wash, but I've noticed 2 differences and I'm looking for some opinions.
as you can see the Zard is a nice looking system with SMOOTH bends and minimal welds.
however the Arrow system is made up of many pieces welded together, not as aesthetically pleasing (if not titanium). But Arrow also claims "The midpipe supplied with these collectors are the short straight through design and do not have the U bend like those found on other stand alone midpipes from other manufacturers."
So any technical thoughts / opinions on welds VS bends or Arrows short straight midpipes VS the "Long Curvy" midpipes? Any fitment issues with either design? Seeing as Arrow is the more established/well know brand I'm guessing there is a reason they weld pieces together instead of bending
ZoeTard is offline   Reply With Quote
Old Nov 3rd, 2008, 1:38 pm   #2 (permalink)
Monstaman's Avatar
I have just bought the Zards, they should be here any day now.
Zard give you the entire headers from front right through to the rear whereas my understanding is the existing tail pipe is still utilized with the Arrows.
The Zard to me seemed to have a nicer looking flow in particular the rear header and the fact it takes out the cat and valve complete swayed me.
I don't know about diameter but the Zard looks like it may be 1 - 2 mm bigger which is not a biggie in the scheme of things but they just seemed to be nicer pipe.
The U bend I think you refer to is the back section up by the mufflers?, I agree the arrow crossover is far nicer than say the Termis, I am going to drill the end cap out I the RHS Termi as it is partialy blanked and creates a heat spot at the point.
My system is Zard headers, Termi slipons and slipon ECU, opened airbox top and bottom and a K&N on its way, that will do me.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Nov 3rd, 2008, 2:52 pm   #3 (permalink)
dave2riff's Avatar
I believe the U-bend they refer to is the one under the motor by the cat. The Leo Vince mid-pipe and the Termignoni cat replacement pipe still retain this sharp U-bend. As far as Zard Vs. Arrow, if you research postings on Arrow full system installs you will see a number of comments on fit and finish quality (like "bring a hammer"). IMO, the Zard looks cleaner, and as you stated, has fewer welded sections. If you don't like the heat shield, there is a carbon replacement on Ebay all the time. I've already disabled my exhaust valve flapper drive (removed cables, installed limiters on the servo motor), so getting the exhaust valve out of there is a plus for reducing dead weight. (Those with DP ECU's don't have to worry about EXV errors.) The Arrow collectors do not appear to replace the section that includes the EXV. I plan on ordering the Zard as soon as the budget allows, in case it wasn't obvious!
Old Nov 3rd, 2008, 4:26 pm   #4 (permalink)
i just got the zards delivered (sorry monstaman, looks like NZ is just that little bit further away..)
Well mixed thoughts, they are one one hand very simple in design, but I guess you get what you pay for.
The welds are shocking
the bends have left machine clamp marks all over the tubes
the clips look like they were spot welded on by a monkey
there are no instruuctions
nothing has been finished ie ground down.
BUT they are cheap, they look easy to install and are better than stock.
I'd say the arrows are a better made system but who cares, its down there under the bike to get hit by shit and go funny colors when it gets hot.
will stick them on this week and see what the go is.
Old Nov 3rd, 2008, 4:39 pm   #5 (permalink)
Monstaman's Avatar
Bastid
Will be keen to see how they fit up etc, really looking forward to getting mine and ditching that bloody hanky out the system.
Cheers KTiMpostor
Monstaman
Old Nov 3rd, 2008, 4:58 pm   #6 (permalink)
08hyper's Avatar
Thumbs up dual diameter......
Just by looking at the pictures, it look like the Zard mid pipe is a larger
diameter than stock, with the no step or taper, which can help the mid to
top power on a non stock performance motor, (cams, HC pistons, porting,
etc.) the stock size header pipe IS better for a stock engine, where the
Arrow pipe looks like the beginning of the pipe looks to start off like the stock
diameter, then tapers to the larger diameter pipe, like the DP performance
pipe, (which is a stepped header design) In dyno testing of different styles
of exhausts for many bikes, I have found that the stepped or tapered
header system seems to produce a better power curve than a straight
larger diameter tube, especially on a stock bike, and also the closer you can
make the individual header pipe the same legnth the better it
will be for power.
IMHO, the Arrow mid pipe, to me would be the better of the two asides from the fitment issues, Aloha Alex
Old Nov 3rd, 2008, 9:30 pm   #7 (permalink)
Duc ... Duc ... GOOSE!
Da_Bull's Avatar
I bought the Arrows.
I'll take pictures when (if) they ever get here.
-Marco
Da_Bull is offline   Reply With Quote
Old Nov 3rd, 2008, 9:46 pm   #8 (permalink)
Monstaman's Avatar
I am in the same boat, bought back on 25 Sept, should be here this week as they have left the US, I think with a global recession you are not allowed to spend money thus you are made to wait
Cheers KTiMpostor
Monstaman
Old Nov 3rd, 2008, 11:11 pm   #9 (permalink)
AXE
AXE's Avatar
I think the Zards look great. I cut the heat guard off and cleaned up the surface. You can clean up the mandrel marks with some fine sandpaper, scotchbrite pad and finish it off with some steel wool. Once it discolors a bit, the imperfections are not that noticeable. You could also coat it to change the overall appearance.
If memory serves me, then the Zard header is 45mm in diameter, while the stocker is 40mm.
You be the judge, but it looks like a serious piece of pipe and dramatically decreases weight.
Out!
2008 Ducati Hypermotard
Old Nov 4th, 2008, 8:44 am   #10 (permalink)
Hyper1's Avatar
Images: 4
sweet
The Zards look very sweet all slicked-up! Nice job on the whole package, as well.
1960 Rupp
1952 Whizzer on Sunshine Bicycle
1963 Sears Allstate Moped
1966 305 Dream
1964 650 BSA Lightning Rocket
1971 XLH 900 HD Sportster
1973 GT 750 Suzuki Water Buffalo
(Mid-life dirt crisis)
2001 1300 XVZ Royal Star
2003 1800 GL Honda Gold Wing
2005 DL 1000 V-Strom
2008 1100 Ducati Hypermotard*
(* sole current stablemate)
Hyper1 is offline   Reply With Quote
Zard Penta slip on : with or without dB killer jpgibson HyperMotard 3 Oct 1st, 2008 9:19 pm
Steel Zard system krilli Sport Classic 19 May 5th, 2008 10:04 pm
Paul Smart Fairing & Zard Exhaust Combo? impax11 Sport Classic 6 Feb 28th, 2008 3:44 pm
ZARD video and images. desmoworks HyperMotard 30 Dec 2nd, 2007 6:03 pm
Zard redux Nash Superbikes 32 Jun 3rd, 2007 9:48 pm
