Ducati Tire Pressure Monitoring System - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Motorcycle.com Classifieds!
Old Nov 3rd, 2008, 11:00 am   #1 (permalink)
Dallara's Avatar
Question Ducati Tire Pressure Monitoring System
Anyone here have any experience or thoughts on Ducati's tire pressure monitoring system, as shown here???
http://www.shopducati.com/ducati_tir...054_p28704.htm
Looks like it would be small, light, and easily mounted. Might be nice to have in certain situations and on longer rides...
Thanks!
Dallara
psychiatrist's office
Dallara is offline   Reply With Quote
Old Nov 3rd, 2008, 11:24 am   #2 (permalink)
You're gonna love my nuts...
Borracho's Avatar
It looks like a rebadged Zadi which I had on my old GS Adventure.
It works great, kinda easy to set/reset tire pressures on the fly. Red LED would flash above/below set temperature and pressure. You can monitor both temp and pressure (display would rotate between the 2) or pick one or the other.
What I never understood was the wheel sensors. There was a flat battery, like a watch/camera battery, siliconed to the circuit board. I know after about 3-4 years the battery would die; what I didn't understand was how to replace it.
Touratech told me that I'd need to purchase a new sensor from Zadi in Germany. I kinda figured that I'd try and silicone in a new one when the time came. Traded the GS for my Hyper prior to that.
Other than the sensor replacement??? It was a great TPMS.
Old Nov 3rd, 2008, 11:53 am   #3 (permalink)
Dallara's Avatar
Thumbs up Cool...
Thanks! I appreciate the info...
How did the pressure sensor mount inside the rims???
Anybody else have any ideas, experience, or info on these rigs or other onboard tire pressure monitoring systems???
Dallara
Old Nov 3rd, 2008, 12:59 pm   #4 (permalink)
Borracho's Avatar
The sensor was sandwiched between the valve stem inside the tire and a nut on the outside. Very easy install; the hardest part was breaking the beads
Mine survived 3000+ miles of dirt/washboard roads, jumps, water crossings, etc...seemed bulletproof IMHO.
I've also heard good things with the SmartTire systems. The display's a little bigger and they mount using a big hose clamp, unless that's changed recently.
Rear Tire Size: 180 vs. 190 Shazaam Hall of Wisdom 0 Sep 13th, 2007 1:32 pm
Found a small nail in my front tire - buy a new tire? koolio Ducati Motorcycle Chat 26 Jul 11th, 2007 12:50 pm
Tire pressure Noob Sport Touring 11 Dec 10th, 2006 7:10 am
How do I do a cooling system pressure test? grendels_arm Superbikes 16 Jun 25th, 2006 9:54 am
Tire pressure galaxy Ducati Motorcycle Chat 1 Jun 4th, 2006 11:11 pm
