HMS Engine Run In Advice
Hi to all,
1000KL on my 2008 HMS in Malaysia, 1st service done with limited advise from the dealer as to best practice for running in the Engine. Only advise was to vary the Rev's and not to run RPM to low.. Next Service at 5000KL.
Idle much better and has stopped stalling at 2500rpm, had the Motard racing seat installed, much better fit and plan to have additional Slip on Exhaust / Clutch stuff etc done at the next service.
Average temperature over here is constant 29 Deg C so it runs hot (115) in town but settles down to around 90 when running.
I ride it to & from work everyday which is about 40KL good hill riding..
Any advise concerning the best run in process would be appreciated
Thanks ABL
Samurai Scotsman
ABL
2008 Hypermotard 1100S (Malaysia) - Full Spec, Termi Race & ECU, Cams, Flywheel, Rollers and Gears, additional Carbon, Race Seat Brembo Levers, Slipper, Ohlins Steering Damper.. Other Bling, Bling..
Planning full race engine upgrade ??
2009 KTM 690SM Duke (Malaysia) - Sold
2007 MV Agusta 910 R Brutale Italia (Malaysia) - Sold
2006 450 KTM (USA) - Sold
2009 (New Yamaha Vmax) SD USA 1/20/09 - Now modified Feb 2011with Full Carbon (All) Powder Coat Exhaust, 240 Back Wheel, Seat, Levers, Mirros and Grips..
