HM-S spring rates question..... - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Motorcycle.com Classifieds!
Old Nov 2nd, 2008, 10:52 am   #1 (permalink)
mental999's Avatar
Does anybody know if the stock spring rates will be ok for for my 215lbs. of pure muscle What kinda sag #'s are you guys getting? thanks
mental999 is offline   Reply With Quote
Old Nov 2nd, 2008, 12:30 pm   #2 (permalink)
Monstaman's Avatar
No, with all that muscle you will be undersprung at that.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Nov 2nd, 2008, 12:48 pm   #3 (permalink)
08hyper's Avatar
I'm 245lbs of pure hard LARD! were both going to need a heavier springs front & rear, my rear sag is set to 35mm by a suspension guy, Aloha Alex
Old Nov 2nd, 2008, 1:32 pm   #4 (permalink)
Monstaman's Avatar
I am 165 lbs so I have the opposite problem with my forks, I am going to do the fork oil and possibly drop a nm on the front springs.
I have set my rear sag to 47 and my forks to 55 although we cannot reach the 55 do to spring strength and my weight.
Wee bit of playing to do yet.
Cheers KTiMpostor
Monstaman
Old Nov 2nd, 2008, 4:09 pm   #5 (permalink)
Suspension settings / new rear spring
I noticed as I was increasing the preload on my rear spring to set my rear rider sag that I was squeezing the spring more than 1-1/4" from the zero preload installed length; (zero preload installed length = the spring installed with no pressure on the spring from the adjustment collar, just enough to hold the spring from moving). Using my ATV racing suspension knowledge I knew I needed a stronger spring. ( I weight 195 lb. naked and about 225 with gear). I contact Ohlins and they listened to my spring theory discussion and totally agreed with me that I needed a stronger spring. the stock spring is a 90 Nm spring and Ohlin suggested that I go to a 100 Nm spring. With the 100 Nm spring installed, here are my currently settings:
Front:
FPL = 8 turns from full soft = about 16mm static sag = about 47mm rider sag (i have made additional adjustments without taking additional measurements, so the values above are approximations based on the current suspension settings)
FCP = 1/2 turn from full soft
FRB = 3 turns from full soft / fastest rebound
rear: 100Nm spring
RPL = 12mm (squeeze on spring) = 18 mm static sag = 49 mm riser sag
RCP = 1 click from full soft
RRB = 19 clicks from full hard / slowest rebound
08 Black HyperMotard 1100s
HerbDon is offline   Reply With Quote
Getting the spring rate right YellowDuck Sport Classic 25 Apr 9th, 2011 8:11 pm
Suspension settings... isse HyperMotard 36 Aug 15th, 2008 2:57 pm
HM fork spring rates speedfreak HyperMotard 22 Jul 9th, 2008 8:33 pm
Can you determine spring rates visually? Gnomad Supersport 4 Apr 22nd, 2007 5:01 am
Ohlins rear spring rates Ragemoto2 Superbikes 4 Feb 19th, 2007 6:27 am
