Dropping forks with rear stand & car jack? - Ducati.ms - The Ultimate Ducati Forum
Old Oct 21st, 2008, 10:31 pm   #1 (permalink)
851
851's Avatar
Before I do something stupid ... what is the best method to drop the forks in the triple clamps without having a front stand or some ceiling hoist? I was think of using my rear stand and a car jack with wood underneath the engine.
Another question, I am presume it is just a case of loosening, equally lowering and then tightening the triple clamps ... no need to removal wheel and therefore no issues if I twist one fork cf to the other.
851 is offline   Reply With Quote
Old Oct 21st, 2008, 11:33 pm   #2 (permalink)
unfast1's Avatar
That's exactly what I did.
2008 Black Hyper S
2005 CBR 1000RR
2001 CBR 929RR
1997 GSXR 600
unfast1 is offline   Reply With Quote
Old Oct 21st, 2008, 11:46 pm   #3 (permalink)
Monstaman's Avatar
Just do one at a time, undo the bolts and quietly rotate the leg backwards and forwards until your height is reached then torque the bolts back up.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Oct 21st, 2008, 11:46 pm   #4 (permalink)
AXE
AXE's Avatar
I have two methods. My Dad built a couple of jack stands that work with my frame sliders to hold the front wheel off the ground for changing tires. The second method I used for setting the rear sag on my bike was to stradle the bike with a heavy duty aluminum ladder (Little Giant in my case), then lift the bike with a pair of soft ties and a heavy duty ratcheting tie down.
Out!
2008 Ducati Hypermotard
Old Oct 22nd, 2008, 12:04 am   #5 (permalink)
I tried this very thing the other day and found there was no way to get the forks moving without making the bike too unstable on the jack. In the end I put some jack stands under the frame sliders and used a bit of water around the fork legs to get them moving - it is a pretty close fit.
2009 Aprilia RSV4 Factory (finally arrived)
2008 Red Hyper 1100S
2008 KTM 690 Duke
2007 Honda CBR600RR
colacin is offline   Reply With Quote
Old Oct 22nd, 2008, 1:12 am   #6 (permalink)
infidel's Avatar
On my other bikes i remove the front wheel and the top triple and do it one leg at a time. That way you don't mark your fork tubes and it makes it alot easier as a one man job. The holes in the top triples are normally smaller in diameter then the forks, so they grip the tubes a bit even when you take the bolts out. So you have to pry the triples open a bit.
On the hyper i don't have a pin tool to remove the top triple, so i left it on. I use a steering stem lifter to hold the bike.
Hypermotard 1100S
Aprilia SXV550
Aprilia RS250
Suzuki RGV250
Old Oct 22nd, 2008, 1:37 am   #7 (permalink)
Chilehead
st2lemans's Avatar
Images: 74
Rear stand is all you need. No need to remove front wheel or top triple.
Tom
1985 LeMans
1986 LeMans w/ sidecar
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
st2lemans is offline   Reply With Quote
Old Oct 22nd, 2008, 7:25 am   #8 (permalink)
HyperMotard21
Guest
Posts: n/a
fork
why are you dropping the fork in the clamp??
also at the track , i used my friend dirtbike stand, put the hyper on it, and with tie down tied up the bike to the stand to keep it from moving....it did work very well...
Old Oct 22nd, 2008, 6:14 pm   #9 (permalink)
iwoolie's Avatar
I put a tow bike hooks in a beam above the bike then use 2 ratchet straps from the bars to the hooks. I like this because you can't nock the bike over / I sent my forks to race tech and left the bike there for a week no worries.
woolie
iwoolie is offline   Reply With Quote
Old Oct 22nd, 2008, 6:43 pm   #10 (permalink)
woolie
that's what I do too
2002 Ducati 998, 1998 Ducati 916, 1998 Ducati 748, 2001 Ducati Monster 750Dark, 2002 Ducati Monster S4 , 1990 Honda Hawk, 1989 Honda Hawk, 1995 Kawasaki Ninja ZX6R, 2001 Harley Davidson, 2000 Buell X1 Lightning, Yamaha TW200
MichMonsterS4 is offline   Reply With Quote
BiPosto rear fender on GT1000... biker7 Sport Classic 13 Dec 12th, 2007 10:26 am
Sport 1000 mono Forks and rear shock brightonduke Sport Classic 0 Oct 24th, 2007 1:13 pm
S P O R T C L A S S I C Rear Break BLACKBIRDXX Sport Classic 22 Aug 26th, 2007 3:27 am
Rear Brake Problems on my 999 427ducati Superbikes 14 Aug 3rd, 2007 8:08 am
