Sconly, If you read my post I did say at HIGHER SPEEDS, and any time you alter the rake of a bike either by raising or lowering either end, it will be the same effect (to a point) "more rake"= more stability harder turning, "less rake"= less stability easier turning, so lowering the front does not give you more stability in turns, just makes it easier "to turn" in fact if you lower the front (decrease rake) too much, it can get dangerous and "fold in." Have you ever ridden a bike that does not have enough rake thru a fast bumpy sweeper?
its NOT fun! For me, I have my rear on the Hyper set HIGH for the MAX ground clearance, and try to find the best balance for stability and turning by raising/lowering the fork tubes. Aloha Alex
