Chain adjust - Ducati.ms - The Ultimate Ducati Forum
Old Oct 17th, 2008, 9:15 pm   #1 (permalink)
Chain adjust
The dealer just did the first 600 mile service. The chain is adjusted different than what the label says. The measurement is more like 42mm than the 33mm the label says. My neighbor also has a new HM and just had his 600 mile service and his chain is about the same as mine. Different shop did the work. Any opinions about this?
trrgod is offline   Reply With Quote
Old Oct 17th, 2008, 9:55 pm   #2 (permalink)
Rduck851's Avatar
Question
Here's one.....Sigh..... Looser = better. Sorry, could not resist.
Rduck851 is offline   Reply With Quote
Old Oct 18th, 2008, 10:38 am   #3 (permalink)
georound's Avatar
Label is wrong...search for details.
Old Oct 18th, 2008, 9:44 pm   #4 (permalink)
when I did the walk around when I picked up the new bike, the dealer said to run the chain with the same tension as it is set at now.... which is way more than 30mm.. not sure why but I will search the threads.
dhc8guru is offline   Reply With Quote
Chain Cleaning, Waxing and WD-40 Shazaam Hall of Wisdom 41 May 9th, 2012 4:11 pm
Chain Inspection and Freeplay Adjustment Shazaam Hall of Wisdom 1 Jan 10th, 2012 11:41 am
Chains and oiling duckbrand Superbikes 31 Mar 21st, 2008 2:33 am
999s Gearing Change Soarer Superbikes 8 Jul 18th, 2007 10:45 am
