Oct 16th, 2008, 1:26 am
Hyper Head Work?
Anybody done any mild head work with gains to report? Mine is a base model and the guy I bought it from put a 2 into 1 SIL Moto with the upgraded Ducati ECU & Airbox whatever, but didn't install the upgraded cams.
I was hoping to get a little more MPH out of it and am considering some mild head work over the winter, but if any of you know this engine and think I just need to install the cams and get a Power Commander so that it can be dyno tuned and get better fuel mapping to manage some good HP gains please lay your advice on me.
Thanks.
Oct 16th, 2008, 1:58 am
If you are doing the cams, you should consider a high compression piston, like
the Pistal's from the Ducshop, in the 11 to 1 or 11.25 to 1 range, it will
add the torque back you'll lose with just the cams, and just give you more
HP everywhere, add if have a few extra dollars laying around, a good clean
and match port job wouldn't hurt either, just don't go wild, I here the heads
flow pretty well on their own.
Personally I'm going to a HC big bore piston, (1123CC) and the porting with
the DP cams, as soon as I hit the 7500mi mark. Aloha Alex
Oct 16th, 2008, 12:24 pm
Oct 16th, 2008, 12:36 pm
I talked with my dealer about getting into the engine over winter. He said that if I was going to the effort of getting in there, to do everything at once. Install the DP race cams, hi-comp pistons and then have some mild head work done. With that done, close to 100 rwhp is possible.
Oct 16th, 2008, 1:14 pm
I did Headwork pistons beast r intake cams ecu and a power commander and it is 104hp and 78 pounds of torque.The bike flat rips
Scotty
08 hypermotard S
08YZF250F SM
06WR450F SM
Oct 16th, 2008, 2:11 pm
Wow, that must be unreal!
I love telling 600cc guys that my bike makes 90hp and 70 pounds of torque. They kind of smile and nod only paying attention to the hp figure and not having a clue what 70+ pounds of torque is like.
Oct 16th, 2008, 7:08 pm
Heads flowed, Termi 2n1, hc pistons, dual hole air box with new filter, dp cams with 2n1 dp chip >100hp with zero miles on bike. pc3 now waiting to get off my lazy ass and carry to friends house with dyno to tune. Awesome combo-bike is an animal. Best wishes.
Oct 16th, 2008, 7:24 pm
Where are you guys getting the port work done? The only place I know of is the Ducshop which charges $900 for the headwork. Way to much money IMO
Anyone got recommendations
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Oct 16th, 2008, 8:43 pm
'08 HM 1100 S
Oct 16th, 2008, 11:44 pm
When you say you did the head work ~ you, or you had it done? Cuz if you did that and got those results, I may want to send some business your way.
