Turn Signals - "LAMP/LED" menu selection question - Ducati.ms - The Ultimate Ducati Forum
Old Oct 13th, 2008, 9:52 am   #1 (permalink)
I have searched and read everything I can find on using LED turn signals and I haven't come up with a clear answer to my problem. I hope somebody can help!
I removed the OEM hand guard/turn signals and hooked up some LED front turn signals but now I've got a rapid flash rate. Although it's something I could live with if I have to, I'd like to slow it down if possible.
There's a menu selection in the "hidden menu" that apparently allows the selection between "LAMP" and "LED". I messed around with it but it did not do the trick. When I set it to LED the indicators don't work at all. So, I wonder if that's because the rear signals are regular incandecent light bulbs?
Anybody know the skinny on this? Specifically, my question is this: if I switch to LED turn signals (front and rear) with no resistors or load balancers, will setting the menu to "LED" make everthing work right?
Any and all insight, thoughts and/or comments will be most helpful and greatly appreciated!
Willi-P is offline   Reply With Quote
Old Oct 13th, 2008, 10:51 am   #2 (permalink)
Caidly's Avatar
Try looking here:
*#+)&* turn signal setting
or
LED Indicator Problems & Flasher Relay?
if you need to know... ask...
Old Oct 13th, 2008, 12:49 pm   #3 (permalink)
Originally Posted by CTarna View Post
Thanks CTarna, I had not found either of those threads in my searches. The info in them gives me a little better idea of what is going on. At least I think so...but, I'm no electrical engineer that's for sure, so, I really don't have a clue.
Still my question is not exactly answered. The question is this: if I replace both front and rear indicators with straight LED signals (no resistors or load balancers) and set to the "LED" selection in the menu will it (1.) work, and (2) will the flash rate be like that of the OEM set up?
FYI, I'd like to avoid the use of resistors or load balancers because I understand they create heat. If that's the only way to slow the flash rate down, I'll probably just opt to live with the higher flash rate. However, if I can just replace the rears with LED indicators (I've already replaced the fronts) and change the menu setting to "LED"and that works, I'll do that.
Thanks for the reply!
Old Oct 13th, 2008, 2:37 pm   #4 (permalink)
yota's Avatar
"Still my question is not exactly answered. The question is this: if I replace both front and rear indicators with straight LED signals (no resistors or load balancers) and set to the "LED" selection in the menu will it (1.) work, and (2) will the flash rate be like that of the OEM set up?"
answer, no. for some reason the menu LED selection will not stay set. I have not resolved this on my bike with the motrax signals, they are still messed up. My last email to Motrax went unanswered. I will bother them some more.
yota is offline   Reply With Quote
Old Oct 13th, 2008, 3:13 pm   #5 (permalink)
Hi yota,
Well that's disappointing.
In my case, when I switch to the "LED" setting it seems to stay set. I say that because when I set it to LED, the signals don't really work at all, then when I reset to LAMP, they work fine except for the rapid flash problem.
Please tell me, are your Mortrax indicators on the rear? What do you have on the front?
Old Oct 13th, 2008, 3:23 pm   #6 (permalink)
yota's Avatar
my logic in saying that it won't stay set is that mine does nothing different and when I go thru the drill again it says "lamp" again every time.
Old Oct 13th, 2008, 5:51 pm   #7 (permalink)
Vdue's Avatar
Originally Posted by Willi-P View Post
Hi yota,
Willi-P
forget all the settings. Leave it on LAMP and install resistors. Follow the link to my webpage, goto Tech->HYM LED Turn Signal, there you find all and everything.
http://www.moto.dotklein.com
1198 SP '11
HYM S '08
Roughneck '07
Vdue is offline   Reply With Quote
Old Oct 13th, 2008, 9:00 pm   #8 (permalink)
V-due. I just went to your website http://www.moto.dotklein.com and got a virus warning for bloodhound something!!!!
not good mate, check that shit out.
Old Oct 14th, 2008, 7:53 am   #9 (permalink)
yota's Avatar
Hi yota,
I have motrax "allycators" both ends. when I just had them on the front everything worked fine. when I added them to the rear a month after I did the front everything went to hell.
Old Oct 14th, 2008, 8:49 am   #10 (permalink)
Originally Posted by Vdue View Post
Willi-P
Hi Vdue,
Thanks for some very good info! I think even I can follow that and calculate the appropriate resistor.
I am, however, still reluctant to install resistors because of the heat warnings. My flash rate is elevated from normal, but I don't think it's bad enough to justify dealing with the heat worries.
Anyway, I'm still curious about the "LED" menu selection. If there is some way it can be used to solve the problem, I'd sure like to know how...anybody know the answer?
Thanks again Vdue. I'll hang on to your info for future reference!
Aluminum LED Turn Signals Sale moto Motowheels 2 Dec 4th, 2008 12:43 am
Rear Turn Signals Relocating Kit theduke HyperMotard 3 May 25th, 2008 2:30 am
Kellermann Micro Polo turn signals moto Motowheels 0 Jan 10th, 2008 2:55 pm
916 Front Turn Signal Question speedrcr Superbikes 8 Aug 1st, 2007 7:11 pm
Need help with my 749 turn signals.... skeezer541 Superbikes 3 Jun 12th, 2006 9:39 pm
