Oct 8th, 2008, 9:29 pm
Hyper not starting on occasion... weirdness
Every now and then after I stop my Hyper... I go to restart it a bit later and the engine light comes on and it won't do anything.... I get all the dash lights etc, but it won't turn over. I then roll it a bit, clutch it, go from neutral to first and back again and whatever, then try again and the engine light is off and it starts up fine. I try it with the clutch in and out, try flicking the starter switch... not sure what causes it to cease and then start again.
Anyone else have this issue? What gives?
Thanks,
B
Never enough garage space.
'05 BMW K1200LT
'07 BMW R1200GS Adventure
'08 Ducati Hypermotard S
'10 BMW S1000RR
Oct 8th, 2008, 10:00 pm
Inspect for loose wires at battery, starter, switches, etc. I haven't had this problem but many can vouch for loose connections.
'08 HM 1100 S
Oct 8th, 2008, 10:41 pm
Thanks,
B
Kickstand down or up?
- '08 Hypermotard S
- '03 Monster 800 (Gone!)
- '98 HD Fatboy (Gone!)
- '95 HD Road King
Oct 9th, 2008, 7:11 am
Up.
'05 BMW K1200LT
'10 BMW S1000RR
