Speedy Moto Sliders?? This far out?? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Oct 6th, 2008, 9:20 pm   #1 (permalink)
So, I installed my speedy moto sliders. But they seem to stick way out.. Are they suppose to stick this far???
nemesisHM is offline   Reply With Quote
Old Oct 6th, 2008, 10:14 pm   #2 (permalink)
hyperdookie's Avatar
Images: 9
When you say "installed" do you mean pulled out rubber plug and inserted slider? I don't have sliders but something looks wrong. I would assume just from your picture, the black part of the slider should be butted up against the frame.I'm sure someone else who has installed sliders will chime in, but until then be careful, this is a critical bolt!
Old Oct 6th, 2008, 10:55 pm   #3 (permalink)
AXE
AXE's Avatar
My R&G sliders stick out a ways too. Maybe not quite that far, but definitely similar. The R&Gs also have a billet aluminum stem extending from the frame tube.
I liked the look of the R&Gs best, but the main objective is to protect the bike and maybe get you back home.
Out!
2008 Ducati Hypermotard
Old Oct 7th, 2008, 12:00 am   #4 (permalink)
The kit came with a new cross beam bolt (engine mount rod) plus the end thread caps, and the slider eurithane sliders which mount the the ends.... Just looks like it extends out pretty far....
Old Oct 7th, 2008, 12:08 am   #5 (permalink)
801
You have them installed correctly. I have them on my HM, and after reading about the frame cracking, I may re-consider.
08 HM-S Red
801 is offline   Reply With Quote
Old Oct 7th, 2008, 12:49 am   #6 (permalink)
frame cracking???? Please explain.. What are the alternatives, and how are they different?
Old Oct 7th, 2008, 7:05 am   #7 (permalink)
Hypremotard's Avatar
I have the speedymoto's and they look the same.
  • '08 Hypermotard S
  • '03 Monster 800 (Gone!)
  • '98 HD Fatboy (Gone!)
  • '95 HD Road King
Hypremotard is offline   Reply With Quote
Old Oct 7th, 2008, 8:45 am   #8 (permalink)
Treadmarks's Avatar
+1
I am fixing to spring for frame sliders and would like to know about the frame cracking issue as well?
TREADMARKS
Ford F150 4x2 Lifted
Treadmarks is offline   Reply With Quote
Old Oct 7th, 2008, 12:26 pm   #9 (permalink)
Originally Posted by Treadmarks View Post
+1
The issue of the frame cracking is what can happen in the event that you do crash and put the sliders to use... Hopefully that never happens, but if so, some people have experienced that although the frame slider reduced some of the damaged, the frame was damaged due to the torque being applied to the frame where the slider is mounted.
Back when I had a Monster and was reading up on frame sliders on the Ducati Monster List website it seemed like the frame damage was hit or miss based on a couple of factors. One being the brand of sliders. Different manufacturers use different material/hardnening methods for the rod they supply to replace the stock engine mounting rod. The cheaper frame slider setups had cheap steel rods which would bend quite a bit before breaking (if they broke at all) which would deform the hole in the frame or bend/crack the frame at the weld. From the research I did, SpeedyMoto was one of the only companies who specifically design their mountin rod to break before bending enough to damage the frame. However, some people still saw frame damage due to the severity of the crash and having a large slider sticking out to instanly snag on things like curbs and grass.
Another factor is the material the slider is made from. The plastic sliders are what I've heard to be the best because they don't tend to "grab" the pavement as much as other sliders which a made from aluminum.
I myself never put my Speedymoto sliders to the test so I can't offer a personal opinion, but as with many things... You get what you pay for.
MotoDuc is offline   Reply With Quote
Old Oct 7th, 2008, 12:47 pm   #10 (permalink)
ak57's Avatar
Images: 6
+1i got mine and then removed them ,apart from that they were sticking way out so i didn't even liked the way they looked on the Masterpiece called Hyper lol
if anybody wants them...............
Riding enjoyment means lightweight motorcycles. Weight is something of an obsession for us.- Claudio Domenicali
ak57 is offline   Reply With Quote
Speedy Moto Frame Sliders WallyAnderson Sport Classic 11 May 14th, 2008 5:38 pm
Speedy Moto fram sliders for a full fairing PS Works!!! PSLE1000 Sport Classic 4 Mar 20th, 2008 10:07 am
Exhaust in Speedy Moto Catalogue on SC1000 glenndesmo Sport Classic 18 Jan 23rd, 2008 6:23 pm
Anyone have the Speedy Moto sliders? Matt-M Sport Classic 16 Oct 12th, 2006 5:54 pm
Speedy Moto Clutch Cover adamtaylorfsu Superbikes 4 Aug 28th, 2006 10:55 pm
