190on the rear? - Ducati.ms - The Ultimate Ducati Forum
Old Oct 5th, 2008, 11:22 pm   #1 (permalink)
eezz's Avatar
190on the rear?
Any body throw a 190 on the rear yet? If so what do you think? If no, any reason I shouldn't?
eezz is offline   Reply With Quote
Old Oct 6th, 2008, 1:31 am   #2 (permalink)
no, the rear wheel is too narrow for a 190 to fit.
Old Oct 6th, 2008, 1:43 am   #3 (permalink)
That's not true. You can fit a 190 on a 5.5" rim if you want to.
But there's no reason to do it. It costs more, and it slows down your handling....
Old Oct 6th, 2008, 8:45 am   #4 (permalink)
you can fit a 190 on a 5.5" wheel, but the profile will change as well as handling
Old Oct 6th, 2008, 8:59 am   #5 (permalink)
Official Sponsor
desmoworks's Avatar
I definitely wouldn't do it even though it is possible. The Hyper absolutely doesn't need a 190 rear.
Anthony Creek
Pro Italia Online || mota-lab
desmoworks is online now   Reply With Quote
Old Oct 6th, 2008, 9:57 am   #6 (permalink)
Caidly's Avatar
Why are you thinking about it?
if you need to know... ask...
Old Oct 6th, 2008, 1:06 pm   #7 (permalink)
kingsnake1650's Avatar
It actually depends on the tire and its construction how it will change the handling. For example Bridgestone race tire are stiff enough that when you put them on a 5.5 rim the tire atually causes the rear of the bike to be higher and the turn in is faster. Most street tire will flatten out giving you more contact patch but will slow your turn in a bit. I assume you want the big fat tire on the rear for looks??
kingsnake1650 is offline   Reply With Quote
Old Oct 6th, 2008, 7:46 pm   #8 (permalink)
eezz's Avatar
I have a few good 190 take offs left over from my GSXR 1000; Pirelli Diablo Corsas, and I know several guys with 600's who race successfully on 190's and they come with 180's. I hate to buy new tires when I have several good sets.
I could care less about the looks, if I were already running 180's and that those lying around, it wouldn't be an issue. I also think the larger patch of rubber on the side of the 190 may work better with the HM torque monster. But it's my first HM (or Duc) for that matter, and I still need to get more miles on it to get used to this new style of riding.
Old Oct 6th, 2008, 8:05 pm   #9 (permalink)
Extended Member
CAlexio's Avatar
ducati uses same 5.5 rim for its 180 and 190 tires so you should be ok. will be interesting to hear how the handling changes.
Old Oct 6th, 2008, 8:11 pm   #10 (permalink)
Monstaman's Avatar
I would have thought it would make the back end more vague to be honest, certainly a flatter contact patch that is for sure
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
GT1000, mounting the rear wheel? 3stephenD Sport Classic 2 Oct 26th, 2007 10:19 am
Shinning light on the Rear Shock rapter Superbikes 37 Oct 14th, 2007 10:02 pm
'95 ss/cr suspension question- bike feels 'greasy' and loose in the rear? svttodd Supersport 14 Dec 17th, 2006 9:44 am
Rear Ride Height Kramer Sport Touring 29 Nov 30th, 2006 9:17 am
Need info on Ohlins rear shock for 996 bconceited Superbikes 2 May 19th, 2006 2:41 pm
