easy way to get the headlight off??? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Sep 24th, 2008, 9:08 pm   #1 (permalink)
I want to move it forward so I can 1. change the bulb 2. adjust the height of one of the forks ( its a few mm out).
The manual states just loosen the top two allen head bolts .How to do this?? You'd need a tiny bloody allen key.Only other option is to remove it all bit by bit.
Any ideas?
jonathan
Old Sep 24th, 2008, 9:33 pm   #2 (permalink)
hammer?
Old Sep 24th, 2008, 9:44 pm   #3 (permalink)
iwoolie's Avatar
You need to remove the fender assembly then remove the three 10mm nuts that hold the speedo and push it up and out of the way, then you can get at the tow small allen bolts. They will strip very easy , I replaced with hex head bolts.
Good luck.
Woolie
iwoolie is offline   Reply With Quote
Old Sep 24th, 2008, 9:53 pm   #4 (permalink)
thanks
sounds too complicated, i think i'll try the hammer first.
jonathan
Old Sep 24th, 2008, 9:59 pm   #5 (permalink)
iwoolie's Avatar
it's not - what are you going to do pay someone to do it for you ? I can do it in 10 min.
Old Sep 24th, 2008, 10:04 pm   #6 (permalink)
infidel's Avatar
Jono, if you are dropping the front wheel out to adjust the front fork heights i've got a steering head lifter if you want to borrow it. Not a very complicated job. Give me a buzz and i'll bring it round. You supply the beer
Hypermotard 1100S
Aprilia SXV550
Aprilia RS250
Suzuki RGV250
Old Sep 24th, 2008, 10:37 pm   #7 (permalink)
kingsnake1650's Avatar
Originally Posted by PedroHM View Post
hammer?
hmm!! techno geek. I was thinking a large stone.
kingsnake1650 is offline   Reply With Quote
Melted my headlight & fairing mostron8 HyperMotard 16 Sep 16th, 2008 9:30 pm
headlight gremlins? need help! kpp80202 Monster 2 Jul 3rd, 2008 8:38 am
ST-4 Owners / Headlight Upgrade AlanS Sport Touring 39 Feb 4th, 2008 4:54 pm
One headlight 748? thatkidchris Superbikes 7 Feb 3rd, 2007 1:50 pm
