Fork Oil Change - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Sep 24th, 2008, 9:35 am   #1 (permalink)
krill's Avatar
Fork Oil Change
Hi, I'm thinking of changing the fork oil to a lighter grade, can anyone tell me the procedure or where I can find it please
krill is offline   Reply With Quote
Old Sep 24th, 2008, 9:44 am   #2 (permalink)
Caidly's Avatar
Why lighter?
if you need to know... ask...
Old Sep 24th, 2008, 10:33 am   #3 (permalink)
krill's Avatar
Originally Posted by CTarna View Post
Why lighter?
Rough roads in my area and the front end feels too hard, other threads seem to say lighter oil is the answer so thought I'd try
Old Sep 24th, 2008, 3:30 pm   #4 (permalink)
Monstaman's Avatar
I to am going to do the same, I have the Morzocchis and have just bought a pin spanner to open them up.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Sep 24th, 2008, 3:48 pm   #5 (permalink)
krill's Avatar
Hi Monsterman, where did you get the tools and how do you drain the oil, how do you refill them and to what level or amount, these are the things I need advice on, I'm confident working on bikes but need to know the procedure, cant find it on my manual disc
Old Sep 24th, 2008, 4:11 pm   #6 (permalink)
Monstaman's Avatar
Heya krill
OK, if you see a piece of rocking horse shit then grab it cos it is as rear as a Marzocchhi fork spanner
I have bought an adjustable pin spanner which should do just what I need.
You can empty the forks through the compression damping hole by undoing the nut and compressing the forks and pumping them up and down.
Each leg holds 550 cc, that is my knowledge thus far, I am unsure as to the setup and how the Marzocchis get refilled and this information is hard to find.
Cheers KTiMpostor
Monstaman
Old Sep 24th, 2008, 5:29 pm   #7 (permalink)
krill's Avatar
Heya krill
Thanks for that, so we still need a bit more info, will post anything I find out
Old Sep 24th, 2008, 6:42 pm   #8 (permalink)
http://www.racetech.com/popupwindow/...lLevelTool.asp
this is the tool you need.
1950 Triumph T-Bird
1954 Triumph T-Bird
1961 Triumph TR6
1969 Triumph Bonneville
1973 Triumph TR5 MX
1969 Harley FLH Shovelhead
2006 Honda CRF 250F
2008 Ducati Hyper 1100S
1969 Meyers Manx Buggy
nog00der is offline   Reply With Quote
Old Sep 25th, 2008, 11:29 pm   #9 (permalink)
Monstaman's Avatar
Update on the fork oil volume, each leg contains 480 ml of oil and come std with 7.5 w oil.
I will be changing mine this weekend if my spanner turns up in time which I am hopeful for.
When in side I will obtain a spring rating, length, wire diameter and number of wraps it has so anyone else wanting to soften the front will have the real oil info.
Chezzi had his done but unfortunately we don't have any further info other than his compression damping has greatly improved.
Cheers KTiMpostor
Monstaman
Old Sep 25th, 2008, 11:35 pm   #10 (permalink)
interesting, I thought Ghez said it was 10w stock..
I'd be interested in doing this if someone can tell me that i can just pop the caps off, drain em and pour in more fluid and do it all back up. anything other than that and i can't be arsed. everytime i work on the bike one of the screws that came out previous either snaps or gets stripped.
848 oil change tweek Superbikes 22 Feb 12th, 2010 12:47 pm
1st -oil change fears CAlexio Ducati Motorcycle Chat 8 Sep 20th, 2008 11:06 pm
Showa Fork Seal Change 748s Superbikes 1 Sep 18th, 2008 6:57 pm
GT1000 Fork Upgrade: Fix what you got! dietrichpfeifer Sport Classic 30 Sep 2nd, 2008 12:40 pm
Oil change question. flyingchappy Sport Classic 29 May 21st, 2008 2:40 pm
