Bike Geometry... - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Sep 23rd, 2008, 7:47 pm   #1 (permalink)
Fly Low...
Karna's Avatar
Bike Geometry...
- Need some Input..
I have Hyper S with 15k love the bike but the suspension seems to have faded a bit and I've really adapted to the bike but I feel the suspension a bit weak in the front "also I weight 220pounds 6' ft not including all the gear stuff" not to mention potential fitting on a new gas tank... I heard from a friend that changing the geometry greatly changed the handling of the bike ... so his advise was as following "He races the Hyper"
1. Move the front forks up as high as they can without touching the handle bars
2. reduce the rear ride height lowest setting...
- So wondering if anyone has done it... second what are the pitfalls doing so...
PS. In the winter I'm planning on getting piston kit and springs from ohlins for the front forks and the correct rear spring... I heard after 15k it's a good idea to have them rebuilt anyways...
Karna is offline   Reply With Quote
Old Sep 24th, 2008, 12:21 am   #2 (permalink)
infidel's Avatar
I would not recommend lowering the rear ride height. Two reasons;
1 you'll slow the steering down
2 you'll have less ground clearance. It is already bad enough as it is.
You should not have to rebuild the suspension after every 15K miles on a road bike.
Hypermotard 1100S
Aprilia SXV550
Aprilia RS250
Suzuki RGV250
Old Sep 24th, 2008, 12:26 am   #3 (permalink)
08hyper's Avatar
Thumbs up Race Tech!
Originally Posted by Karna View Post
- Need some Input..
Go to the Race Tech web site, they now have lighter & heavier springs as
well as damping kits for the front forks. Aloha Alex
PS: I'm thinking if you go with the bike lowering set-up you WILL quickly
run out of ground clearance, I have RAISED both ends and still run out of clearance, pegs, shift/brake lever, and pipe drags on mine!
Old Sep 24th, 2008, 2:49 am   #4 (permalink)
johnchypermotard's Avatar
any idea as to the pricing on the G2-R 25 mm CARTRIDGE KITS and the springs from race tech?
Old Sep 24th, 2008, 7:27 am   #5 (permalink)
Around $1200
Scotty
08 hypermotard S
08YZF250F SM
06WR450F SM
scottysspeedshop is offline   Reply With Quote
Old Sep 24th, 2008, 9:09 am   #6 (permalink)
Caidly's Avatar
How about the full cost to swap for the new 2009 front end?
if you need to know... ask...
Old Sep 24th, 2008, 9:19 am   #7 (permalink)
Thumbs up
How about having a real suspension tech set your suspension up ?
lugger is offline   Reply With Quote
Old Sep 24th, 2008, 10:07 am   #8 (permalink)
ADHD's Avatar
I agree. I left my forks in the stock location and raised the rear 20mm for even quicker handling. I have to hang off the bike superbike style to keep from hitting the pegs in tighter corners.
Successful and unsuccessful people do not vary greatly in their abilities. They vary in their desires to reach their potential.
John Maxwell
ADHD is offline   Reply With Quote
Old Sep 24th, 2008, 1:54 pm   #9 (permalink)
Caidly's Avatar
Did you get down to NJMP?
Old Sep 24th, 2008, 2:29 pm   #10 (permalink)
ADHD's Avatar
Unhappy
I am supposed to go this Saturday. But with the tropical storm beginning tonight, I think I am going to cancel.
John Maxwell
Geometry! SAC Superbikes 0 Jul 10th, 2008 3:11 pm
749/999 Geometry easye Superbikes 0 Jul 4th, 2008 5:29 pm
748 Geometry Questions boostedt0y Superbikes 11 Jun 6th, 2007 12:34 am
Geometry Question...New Penske Shock galaxy Superbikes 7 Jun 3rd, 2007 9:27 pm
SBK fork verses SS fork geometry fester Supersport 2 Mar 10th, 2007 5:56 pm
