reset tps...what a difference - Ducati.ms - The Ultimate Ducati Forum
Old Sep 19th, 2008, 7:47 pm   #1 (permalink)
I installed the termi slipons, DP ECU, airbox cover, and LV cat eliminator about a week ago. It looks great and sounds great but the idle was all over the place and was running really rich for some reason. I finally got over to the dealer to have the tps reset and fuel trim adjusted, and all I can say is that it makes a world of difference. The idle is rock solid, and now after a ride doesnt smell like gas is leaking all over. The hurky jerky slow speed manuevering is way better and the power delivery feels super smooth and linear according to the butt dyno. I'm cant believe how smooth it runs now, much better than it was stock.
vinneyt is offline   Reply With Quote
Old Sep 19th, 2008, 8:50 pm   #2 (permalink)
johnchypermotard's Avatar
cool ... now you know how the hyper "should" run.
as your in san jose, will you be attending LDD2008 on oct. 12th?
a presto,
johnc
Old Sep 19th, 2008, 9:03 pm   #3 (permalink)
Yeah I usually swing by there every year,even though I had an R1 at the time, but this year I'll be there for sure.
Old Sep 19th, 2008, 10:04 pm   #4 (permalink)
cool ... if you have not had your tard's suspension set up yet, jim lindemann will be there the entire day, doing his wrench spinning magic adjustments:
Sportbike Suspension Setup Clinic
The Lindemann Engineering Sponsored Sportbike Suspension Setup Clinic will be run by Jim Lindemann, where he will measure and tune your motorcycle's suspension to match your weight/riding style, all for a $50.00 donation to the La Honda Fire Brigade.
Old Sep 19th, 2008, 10:29 pm   #5 (permalink)
hyperdookie's Avatar
Images: 9
Nice.Sounds like a deal. I've been a little reluctant to touch my rear preload after seeing AZ Scotts post about the nylon adjuster nut.That was ugly! I am by no means a suspension guru so it would be nice to have a pro get the baseline settings in the ballpark.I assume this is on a first come first served basis?
Old Sep 20th, 2008, 12:19 am   #6 (permalink)
Lifetime Premium
Images: 59
Lindemann set-up my suspension and the bike went from virtually unrideable (after I installed the Termi 2-1) to being on-rails.
Tip: Spray some light lubricating oil (i.e., Belray 6-in-1) on the shock spring preload adjuster rings a week or so before attempting to adjust them. In so doing, you will greatly minimize the risk of galling the threads.
Bill
2008 KTM 990 Adventure
2007 KTM 640 Adventure
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1978 Moto Guzzi Lemans I
1974 Yamaha RD350
1931 Moto Guzzi 2VT
can U reset the TPS and adjust idle? Not the dealer? hyperichie HyperMotard 1 Sep 2nd, 2008 9:19 am
TPS Adjust. duc900 Supersport 1 Jul 3rd, 2008 10:47 am
TPS setting on 999S using VDST gnuoyfj Superbikes 14 Mar 21st, 2008 11:37 pm
Tps Reset Tool curlylee HyperMotard 5 Mar 11th, 2008 6:47 pm
Does disconnecting battery reset TPS josephvman HyperMotard 9 Mar 9th, 2008 12:11 pm
