Rubber gasket under clutch cover? - Ducati.ms - The Ultimate Ducati Forum
Old Sep 19th, 2008, 10:50 am   #1 (permalink)
Hypremotard's Avatar
Hi, Just replaced the clutch cover on my bike. Is it safe to say that the rubber gasket that was with the OEM cover doesn't get put on with the billet replacement? I assumed since the new cover is open anyway there isn't much to seal in or out of the clutch compartment.
You know what they say happens when you ASSuME right?
TIA,
Tom
  • '08 Hypermotard S
  • '03 Monster 800 (Gone!)
  • '98 HD Fatboy (Gone!)
  • '95 HD Road King
Hypremotard is offline   Reply With Quote
Old Sep 19th, 2008, 11:51 am   #2 (permalink)
slowpoke's Avatar
TIA,
Tom
you don't need it for aftermarket cover...
slowpoke is offline   Reply With Quote
Old Sep 19th, 2008, 1:16 pm   #3 (permalink)
Thank you.
  • '08 Hypermotard S
  • '95 HD Road King
Old Sep 19th, 2008, 1:28 pm   #4 (permalink)
Caidly's Avatar
It's a noise damper, that's why it's rubber and not a regular paper gasket.
Just make sure you put a little LocTite on the bolts holding the new cover on.
if you need to know... ask...
Old Sep 19th, 2008, 9:07 pm   #5 (permalink)
mountainrider's Avatar
Location: i see twisty roads..., and I like it, I Like it a lot!
Images: 11
TIA,
Tom
If Eric Wood of Woodcraft tells you to do something, you'd better pay attention.
I yanked the carbon cover off my 93 900SS and was running it on the hyper. It's visible in my sig pic. It was installed within a few months of buying the bike in 92 and was quite weathered. I decided to order a Woodcrat cover to go with my Woodcraft rearsets. I popped off the old cover, which I had run for a month without the gasket, and bolted the new billet cover in place....without reading the instructions.
The Hyper would barely crank. It sounded as if the battery was on it's last leg. The Bike was new in May this year. That made me go hmmmmm.
Upon removing the cover, I found a nice gouge on the inside where the spring cap had fouled the alloy. Sure enough, upon reading Erics instructions, I found my mistake. "You must refit the stock gasket when mounting the clutch cover".
I don't think you have to use it with most of the other options, but you certainly do with this one.
Fresh Air, Frenetic Road, Agile Bike
.....<a href=http://www.youtube.com/watch?v=B1UYsN5u5No target=_blank>http://www.youtube.com/watch?v=B1UYsN5u5No</a>
mountainrider is offline   Reply With Quote
Old Sep 20th, 2008, 4:36 am   #6 (permalink)
Werloc's Avatar
Images: 6
I used mine.
Werloc is offline   Reply With Quote
Old Sep 20th, 2008, 7:18 am   #7 (permalink)
Banned
Me too.
Old Sep 20th, 2008, 7:54 am   #8 (permalink)
Performance Center
Ducshop's Avatar
I remove the rubber gasket but pull the inserts out and put them back to keep it spaced out, looks cleaner and keeps the rubber from staining the paint.
Old Sep 21st, 2008, 3:42 pm   #9 (permalink)
Lumpy Idol's Avatar
Images: 21
This is 100% correct.
As for running it with aftermarket covers, it depends on how the cover was designed - to use with or without.
If you can run without it - then its' better to not use the gasket.
Lumpy Idol is offline   Reply With Quote
Old Sep 22nd, 2008, 3:33 pm   #10 (permalink)
I took out the rubber gasket on my clutch cover as well. You just have to make sure and use the spacers so nothing rubs. The clutch noise it a lot more audible with the gasket out. It sounds great now.
breakdown is offline   Reply With Quote
New Clutch, Decisions, Decisions ... Shazaam Hall of Wisdom 6 May 19th, 2011 9:00 am
Custom clutch cover (stud pattern??) russh Superbikes 0 May 13th, 2008 2:54 am
Carbon Fiber Clutch Cover Question? mafpolo Superbikes 20 May 7th, 2008 10:35 pm
Paint clutch cover? Desmo_749 Superbikes 2 Jun 11th, 2007 9:42 pm
Anyone ever crash tested a MadDuc clutch cover? DrGonzo Ducati Motorcycle Chat 5 May 12th, 2007 6:04 pm
