Thought I'd share my recent experience with Apex Moto in Anaheim and my dyno results.
I purchased the PowerCommander from them over the phone. They had advertised on Craigslist with a free dyno run. I couldn't find a better price, so purchased on for Hypermotard. I installed the PCIII in about 20 minutes and was very carefull not to break the plastic after seeing how brittle the fairings are on these bikes.
My bike is an 08 S model and has Leo Vinci cat eliminator, Termignoni slip-ons, Termi ecu and the airbox lid. I've removed the flapper valve.
I've been trying to get the air bleed screws somewhere close to where they should be by trial and error.
After Francis ran my bike a couple of times on the dyno, he found that it was running pretty lean with the current map. This was a tweaked version of one from a Paul Smart LE 1000 with a full system. Since the A/F mixture was pretty far from ideal, that map wasn't doing me any favors. I've since added around +8 to +10 in various rpm ranges to see if it felt any stronger. My seat of the pants dyno says that it might pull abit stronger. I also richen the bleed screws a quarter of a turn after seeing 14.5 or so CO at idle. Seems to idle a bit better.
If you have experience with a power commander and would like to give me some constructive feedback, I can post the map used for the run and the map I have loaded now. As I've spend a fair amount of money this month, I've decided to play around with it myself rather than spend the $300 for a custom map. I'm sure that Francis would do a great job as Apex has the newest Dyno and he's really dialed in his PS1000LE.
In hind sight, I should have ran it once with the zero map to see how close the Termi ECU was. Then again with my map. That way, I could see the differences and have a better clue where to tweak the numbers.
