First Service - Ducati.ms - The Ultimate Ducati Forum
Old Sep 18th, 2008, 5:18 pm   #1 (permalink)
First Service
Well, my hyper has been in the shop for 18 days since I've owned, so, I'd rather keep the down time to a minimum for now. I"m due for my first service (500 miles). Now, this is my first Ducati so I'm not as familiar with how they do things. Pretty much every other bike I've had serviced, the first one was pretty much a glorified oil change that they charge you up the ass for. So, I'm thinking that since my bike has been in the shop for 18 days that it has been inspected fairly well. So, my question is can I just do the oil change myself? I'm guessing that it's the standard new oil and oil filter routine. Any thing I should be aware of?
mdemers883 is offline   Reply With Quote
Old Sep 18th, 2008, 5:22 pm   #2 (permalink)
ak57's Avatar
Images: 6
stamp the warranty book!!!!
tighten all bolts!!!
Riding enjoyment means lightweight motorcycles. Weight is something of an obsession for us.- Claudio Domenicali
ak57 is offline   Reply With Quote
Old Sep 18th, 2008, 6:46 pm   #3 (permalink)
work order writeup on first service
  • check and adjust spark plug gap
  • check and adjust chain tension and lubrication
  • check and adjust timing belts
  • check and adjust flexible cables
  • check and adjust brake hydraulic controls
  • throttle body synch and idle adjust
  • check and adjust steering bearings
  • check proper operation of radiator fan if equipped
  • check air filter
  • clean engine oil intake filter
  • replace engine oil and filter
  • check coolant level if applicable
  • check clutch and brake control fluid
  • check wear on brake pads
  • check tire pressure
  • torque nuts and bolts to factory specs
  • general lubrication
  • road test motorcycle
parts total ~ $50
1 hour labor ~$75
some of the items above should give you a good belly laugh.
nothing to hard or difficult that you couldn't do yourself.
I'm just laaaaaaaaaazy and ride. I don't mind somebody else doing the wrenching as long as the charges are reasonable
eechan is offline   Reply With Quote
Old Sep 18th, 2008, 7:04 pm   #4 (permalink)
Images: 4
The factory intial service regimen does not include cam belt inspection.
Mine were very loose and the dealer uses a special tool to "tune" the tension, it is 80hz, FWIW.
berndt is offline   Reply With Quote
Old Sep 18th, 2008, 7:12 pm   #5 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
My belts were also very loose. Especially the vertical cylinder. You can use a guitar tuner program with your PC along with a mic to get it done. I used the less precise 45 degree twist to adjust mine.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Sep 18th, 2008, 9:27 pm   #6 (permalink)
Images: 4
My horizontal cylinder was 55Hz, and the vert was 115Hz.
Old Sep 18th, 2008, 9:41 pm   #7 (permalink)
Are there any other particulars for the belt check? My covers need to come off for a look/adjustment.
HYPRmoTARD is offline   Reply With Quote
Old Sep 19th, 2008, 12:26 am   #8 (permalink)
Kamperkitjay's Avatar
Images: 10
Whats a ballpark price on that first service?? mine is coming up fast.. What did it cost you guys?? what can I expect??
Kamperkitjay is offline   Reply With Quote
Old Sep 19th, 2008, 5:36 am   #9 (permalink)
mountainrider's Avatar
Location: i see twisty roads..., and I like it, I Like it a lot!
Images: 11
Aren't we still using the 5mm allen go/no-go gauge on the 2 valves like I have for the last 15 years with my 900SS? The guitar tuner thing is cool. I had not thought of that.
Fresh Air, Frenetic Road, Agile Bike
.....<a href=http://www.youtube.com/watch?v=B1UYsN5u5No target=_blank>http://www.youtube.com/watch?v=B1UYsN5u5No</a>
mountainrider is offline   Reply With Quote
Old Sep 19th, 2008, 10:11 am   #10 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
The guys on the SS/SC board said that the idler rollers on each cylinder are at different distances from their respective cam pulleys so the allen wrench method no longer works.
-2008 Hypermotard S
-2005 Buell XB9SX
-2005 CRF170R
Secret Ducati Service Bulletin - All owners must read JEC Ducati Motorcycle Chat 21 Jan 9th, 2010 11:47 am
Pro-Italia service nog00der HyperMotard 60 Dec 1st, 2009 9:04 am
2007+ Ducati Maintenance schedules/costs revealed Nitrouz Superbikes 12 Nov 16th, 2007 5:15 pm
Service interval for 999s - can't find in "Hall of Wisdom"! Draven Superbikes 8 Oct 29th, 2007 9:11 pm
Refused Service on my Ducati at a Ducati Dealership hawc Ducati Motorcycle Chat 73 Feb 10th, 2007 7:31 pm
