Track Day Tape - Ducati.ms - The Ultimate Ducati Forum
Old Sep 18th, 2008, 11:55 am   #1 (permalink)
Robert's Avatar
Track Day Tape
Got a couple of track days coming up in about a week at NJMSP and I need to tape my lights up ,I usually use painters tape. My question is do I need to pull the fuse for the lights ? It seems to get pretty warm and I dont want to melt anything but would like to avoid pulling body work to get to the fuses. Anyone with any info would be helpful...thanks
Robert is offline   Reply With Quote
Old Sep 18th, 2008, 2:11 pm   #2 (permalink)
Official Sponsor
desmoworks's Avatar
I like to pull the fuse on my bikes, but you probably won't have too much problem with the painters tape. I've had the light on before with the tape and it didn't create any problems. I'd be leary with some other tapes though as you'll have a mess on your hands.
Anthony Creek
Pro Italia Online || mota-lab
desmoworks is offline   Reply With Quote
Old Sep 18th, 2008, 2:42 pm   #3 (permalink)
piarjr's Avatar
Cool
Well, I use painters tape, and remove the fuse, since I remove the seat, to unplug the connectors for the blinkers, license plate and break light, I remove the right side panel and take the fues out..
piarjr is offline   Reply With Quote
Old Sep 18th, 2008, 2:44 pm   #4 (permalink)
ADHD's Avatar
Robert, what organization do you do track days with? On 9/27, I'll be at NJMP on my RC51. I'm a member of Team Promotion.
Successful and unsuccessful people do not vary greatly in their abilities. They vary in their desires to reach their potential.
John Maxwell
ADHD is offline   Reply With Quote
Old Sep 18th, 2008, 3:40 pm   #5 (permalink)
Robert's Avatar
thanks for the info guys,I will most likely go and pull the fuse to be safe
I am there with Team Promotion ADHD,will be there the 27th and 28th
lets say hello,I will be the guy with lots of gray hair and a hyper
Old Sep 18th, 2008, 3:53 pm   #6 (permalink)
Caidly's Avatar
Ewwww, team SELF-promotion.
if you need to know... ask...
Old Sep 19th, 2008, 11:13 pm   #7 (permalink)
851
851's Avatar
My track day preps
Pulling the fuse is the way to go ... easy to do, rhs flaring has the rubber fuse box, remove the one in position number #2 if my memory serves me well.
It is also easy to remove number plate assembly, indicators and rear brake light (30 mins). For that you do end up getting under the seat, removing connectors and tie-wrapping cables. You then discover some Italian aspects of your bike ... inconsistent bolt sizes and use of washers, rubber mountings that are torn by the factory / or dealer (I had the 1-2 system installed by dealer, maybe it was done then).
Painters tape is great, comes of easily (I have not done it with lights on.) One learning from my recent track day was that the bike number stickers given out on the day left lots of adhesive and torn-up when removing. I would recommend first laying down painters tape where you want to put the # stickers and then place the stickers on top of the tape. That way removal would be just like removing the painters tape.
851 is offline   Reply With Quote
Old Sep 20th, 2008, 6:05 am   #8 (permalink)
Robert's Avatar
good point ...thanks
Old Sep 20th, 2008, 8:52 am   #9 (permalink)
8850's Avatar
Images: 5
Same here and it worked well.
8850 is offline   Reply With Quote
Old Sep 20th, 2008, 9:07 am   #10 (permalink)
daversj's Avatar
I've been using wide black electrical tape without a problem. By design it has a high heat adheasive. It leaves no residue if removed in a day or two. Even over a running headlight no glue problems. I also remove the plate, tail light assembly, it's real easy.
2008 Hypermotard Temrmi Slipon w/ Zard collectors & Mid pipe, 2 into 1 Termi ECU
daversj is offline   Reply With Quote
Sydney Track Day? MY45 HyperMotard 23 Sep 17th, 2008 8:32 pm
Track Day photos zx250r Superbikes 10 Aug 5th, 2008 11:31 pm
Track Day Schools in California? breakdown Ducati Motorcycle Chat 3 May 14th, 2008 12:53 pm
Long Weekend track Day at Sentul Nugroho Ducati Motorcycle Chat 17 Mar 22nd, 2008 11:07 am
