swapping ECU, any tips? - Ducati.ms - The Ultimate Ducati Forum
Old Sep 18th, 2008, 12:33 am   #1 (permalink)
disconnect battery?
any special magical sequence with the key switch and mode switch?
also wondering what happens to the odometer...
1950 Triumph T-Bird
1954 Triumph T-Bird
1961 Triumph TR6
1969 Triumph Bonneville
1973 Triumph TR5 MX
1969 Harley FLH Shovelhead
2006 Honda CRF 250F
2008 Ducati Hyper 1100S
1969 Meyers Manx Buggy
nog00der is offline   Reply With Quote
Old Sep 18th, 2008, 2:14 am   #2 (permalink)
oh ya,
also, are the header gaskets crush washers? are they reusable?
1950 Triumph T-Bird
1954 Triumph T-Bird
1961 Triumph TR6
1973 Triumph TR5 MX
2006 Honda CRF 250F
Old Sep 18th, 2008, 7:45 am   #3 (permalink)
uzirider's Avatar
Good thread to explain setting your country code after ecu swap.
Hidden "Service Menu"
If its the slipon ECU, i would visually check the position of the exhaust valve with the stock ecu. I was unlucky and got a DP ecu that was closing the exhaust valve. So i had to modify the exhaust valve servo to trick the ecu into thinking it was still connected.
After reconnecting the battery. You will have to set your country and reset the clock. But the mileage is retained.
Since i just loosened the headers to fit my Cat eliminator, i dont know if the header gaskets are crushable. But i retorqued them and have no exhaust leaks. Im sure one of the old wise ducati poeple here can give insight.
Protect your nuts..
08 Hypermotard 1100s
05 CRF450
uzirider is offline   Reply With Quote
Old Sep 18th, 2008, 8:37 am   #4 (permalink)
uzirider's Avatar
Of course the service manual says to replace the seals. Just browsing also looks like the 2-1 termi system comes with the new gaskets. Not sure what your installing though.
Protect your nuts..
05 CRF450
Old Sep 18th, 2008, 11:03 am   #5 (permalink)
Dallara's Avatar
Post Exhaust gaskets...
You really should replace the exhaust gasket if you take off the header pipes.
The OEM Ducati exhaust gasket are made of thin aluminum form into sort of a "U" shape on its side, with aluminum then on the top, inside, and bottom of the circular gasket. Inside this "U" section is an off-white composite material that gets compressed and sort of squeezes outward when the gasket is compressed. Neither the composite material and aluminum have any sort of "memory" so they do not return to their original shape and form... i.e. once they are compressed they are compressed forever.
One would guess they get "work-hardened" if they are run on the bike for any real length of time from the high of having to work in the exhaust port.
If you ever see a new Hyper exhaust gasket you'll know exactly what i mean.
Only saving grace is that unlike most Ducati parts they are cheap. I bought four the last time I was getting a set just because they were so cheap and I wanted to have a spare set around if I needed them.
Hope this helps!
Dallara
psychiatrist's office
Dallara is offline   Reply With Quote
Old Sep 18th, 2008, 11:11 am   #6 (permalink)
that thread is helpful yes, but since i got my DP ECU seperately and with no instructions. and i have installed a full exhaust. i want to know basically how to swap ECU's, and if there is any magical order in which to to it.
1950 Triumph T-Bird
1954 Triumph T-Bird
1961 Triumph TR6
1973 Triumph TR5 MX
2006 Honda CRF 250F
Old Sep 18th, 2008, 3:02 pm   #7 (permalink)
uzirider's Avatar
Nothing special.
Disconnect battery. Remove right side fairing/shroud. Push in the little tab on connector which allows you to turn the cam locking device. As you rotate the connector latch/cam device(not sure what to call it) the connector will pull its self straight out. No worries of bending pins.
Unbolt the ecu and mount the new dp ecu. Make sure locator pins are facing towards bike. And make sure the grounding wire is under bolt head. Thats about it.
swapping ECU, any tips?-hym1100smy08_m_3_4_00.57.1.4.jpg   swapping ECU, any tips?-hym1100smy08_m_3_4_00.57.1.7.jpg   swapping ECU, any tips?-hym1100smy08_m_3_4_00.57.1.10.jpg
Protect your nuts..
05 CRF450
Old Sep 18th, 2008, 3:33 pm   #8 (permalink)
Nothing special.
aah, THANK YOU! just what i needed to know.
1950 Triumph T-Bird
1954 Triumph T-Bird
1961 Triumph TR6
1973 Triumph TR5 MX
2006 Honda CRF 250F
DP ECU for Hypermotard interchangable with Sport Classic? garth Sport Classic 7 Jan 12th, 2009 7:13 pm
ECU problem st2lemans Ducati Motorcycle Chat 2 Jun 29th, 2008 4:14 pm
15M ecu - help! dirkwrong Ducati Motorcycle Chat 7 Mar 28th, 2008 7:46 am
powercommander, rapidbike, techlusion, DP ECU, or ultimap? stlouisrider Sport Classic 5 Mar 14th, 2008 9:36 pm
