OK, I got spoiled on my Buell with the preload knob.
I bought the two special ohlins spanners...but Dayyuum what a PITA to make preload changes.
Any one want to share some secrets (other than taking it to the dealer)?
I was going in this direction, for a 180 lb rider solo.
FRH- forks lowered to the cap
FCD- 1 turn out
FRD- 3 turns out
FP- 7 turns in (needs a stiffer spring)
RRH +1 turn from stock
RCD 7 clicks out
RRD 21 clicks out
RP .5 to 1 less than stock (also needs a stiffer spring-no static sag and 35-40mm rider sag)
TREADMARKS
Ford F150 4x2 Lifted
