Sep 17th, 2008, 3:18 pm
Service indicator
Is there any way, other than taking it to the dealer, to get the service indicator to go away from the instrument panel?
TREADMARKS
Ford F150 4x2 Lifted
Sep 17th, 2008, 3:46 pm
Buy the expensive dealer ECU tool.
if you need to know... ask...
Sep 17th, 2008, 3:56 pm
Eat, sleep, play!
You can reset the service indicator with the VDSTS tool.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Sep 17th, 2008, 4:55 pm
How much is that?
Since it's just a picture of a wrench, it doesn't really bother me. It's not like it flashes "MAINTENANCE DUE" or something obnoxious like that.
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
Sep 17th, 2008, 5:31 pm
They are about 200 dollars from technoresearch. Do a search here to find out more about. Good luck.
Oct 9th, 2008, 9:40 am
I found this...it appears to be able to reset the service indicator and then some...
http://www.ferracci.com/store/cart.p...ct_detail&p=68
Looks like a repackage of the technoresearch unit.
$200 is pricy but doing all your own service will save you alot more than that over the dealer.
Oct 9th, 2008, 1:53 pm
On Ducati models with separate tach/speedo clocks, the instrument panel has two buttons that perform the same type of switching as the mode switch on the Hyper's left switch block. On these models, like the Sport Classics, you could manually reset the service indicator using this routine:
1. Insert key
2. Depress and hold the left instrument panel button
3. Turn key on with button still depressed
4. Let instrument cluster cycle to "on" mode
5. Turn key off with button still depressed
After this, you restart your bike like normal and the indicator is reset. I have no idea if the Hyper's instrument panel is configured in a similar fashion, but if it is, some combination of holding the mode switch in the "A" or "B" position while keying on and off might work. I had a chance to try it on my GT but haven't reached that mileage yet on the Hyper.
Andy
08 Hypermotard S (red)
07 GT1000 (gray), traded for Hypermotard
06 Genuine Buddy 125
04 Aprilia 50cc 2 stroke, 65 cc cylinder head, touring exhaust, RIP
Custom road bike, Ciocc steel frame, campy road set
