My Hyper is leaking oil. :( - Ducati.ms - The Ultimate Ducati Forum
Old Sep 17th, 2008, 2:24 pm   #1 (permalink)
I have noticed a while ago some oily black residue in front of the clutch cover and around the bottom right side of the engine. I couldn't find where it was coming from. I didn't pay attention too much but recently I noticed that it was coming back after every long ride and getting worst. I went to my dealer and we found out that the oil is probably coming from the shaft seal behind the belt cover. The belt then spray the oil all over inside the cover and of course this belt cover is not meant to be oil-proof so the oil ends up everywhere under.
Now I remember other users here noticing the same oily black trace. You might wanna check with your dealer.
I should have more details this Friday.
EZJeff is offline   Reply With Quote
Old Sep 17th, 2008, 2:34 pm   #2 (permalink)
georound's Avatar
Mine had put quite a bit of oil along the bottom of the engine. I found that the oil filter was pretty lose... gave it a quarter turn and it's cleaner!
Oil leaking from Clutch area? Need diagnostic help (lots of pics) 56k beware! indetrucks Superbikes 36 Jan 29th, 2009 8:03 am
748 oil cooler install Bravo51 Superbikes 16 Jul 12th, 2008 12:22 pm
? about bike on side and leaking some oil.... ducduc Superbikes 1 Jul 2nd, 2008 2:48 pm
Hyper on superbikes with oil leak ed218 HyperMotard 7 Jun 15th, 2008 1:34 am
oil sensor leaking on my 996 help please! DesmolitonMan Superbikes 8 May 17th, 2008 11:43 am
