Leo Vince & Hello - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Sep 14th, 2008, 10:09 pm   #1 (permalink)
desmolvr's Avatar
Leo Vince & Hello
Just purchased a new Hyper black to go with my Yellow 1098. I am curious about the Leo Vince system. I am looking at that with a cat eliminator and the DP cams with ECU. Is anyone running this config? If so how is the performance and the extra pipe on the left? The other system I thought is the Zard Penta. Any advice or opinions would be great.
Thanks
desmolvr is offline   Reply With Quote
Old Sep 15th, 2008, 12:17 am   #2 (permalink)
AXE
AXE's Avatar
There is an ECU on eBay for sale. You will need it if you purchase a can other than a Termi from DP.
The Zard stuff is made really well and looks great. I have the Top Guns. You can get the stuff from Desmoworks.
The LV makes some nice HP and is less expensive than most systems. I don't think it looks as good as other choices and some people have had problems with the pip hitting their huggers.
Out!
2008 Ducati Hypermotard
Old Sep 15th, 2008, 12:55 am   #3 (permalink)
Brainfry's Avatar
Thanks
Love my Leo's. Full system with midpipe/cat eliminator. No other mods other than dropping a tooth on the front sprocket. LV tests their kits with the stock ecu and I saw no reason to change anything. Mind you I never had it dyno'd, but that being said, I'm happy with the power delivery and throttle response. It also sounds WAY better than the Termi's IMHO. With or without the restrictor... but without it's LOUD. As for hitting the rear hugger... yeah, it hits a bit, but big deal. I think they look great and the craftsmanship and fit are top notch.
Go for it,
B
PS: Instructions were a bit tough to read (postage stamp schematic) but any one of us who've done the install can help.
Never enough garage space.
'05 BMW K1200LT
'07 BMW R1200GS Adventure
'08 Ducati Hypermotard S
'10 BMW S1000RR
Brainfry is offline   Reply With Quote
Old Sep 15th, 2008, 9:58 am   #4 (permalink)
desmolvr's Avatar
Thanks for the input. I would also be adding the DP race cams & ECU so either system should work. IMHO they both look good I was just not sure about the way LV has the two pipes under tail.
I was going to put the Zard on my 1098 but found a good deal on a set of Graves. There was no need for additional power on the 1098 (unless you run a lot of fast tracks). The Hyper does feel a little under powered and I think exhaust and cams would do the trick.
Old Sep 16th, 2008, 9:01 am   #5 (permalink)
HYPERR's Avatar
AXE, does Desmoworks sell a ECU that works with the Top Gun? If so, how much is the whole pkg? I currently have the stock ECU with just a Leo Cat Eliminator. I eventually want to get the DP airbox lid and the Top Gun, and whatever ECU that is necessary.
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
Old Sep 16th, 2008, 11:38 am   #6 (permalink)
Go for it,
B
On LV's website I found only two options and they both appeared to be slip ons....do they sell a full system on the website?
thanks!
scmi0001 is offline   Reply With Quote
Old Sep 16th, 2008, 4:36 pm   #7 (permalink)
MarksFriggin's Avatar
LV only makes the slip on and a cat eliminator. They don't have a full system.
Old Sep 16th, 2008, 4:40 pm   #8 (permalink)
yota's Avatar
don't see any good reason to toss the stock headers anyway.
yota is offline   Reply With Quote
Old Sep 16th, 2008, 4:58 pm   #9 (permalink)
Brainfry's Avatar
I didn't replace the headers. But when a pipe goes back to the midpipe and replaces the cat, I normally refer to it as a "full" vs. a "slip on"... where just the cans get slipped on... semantics.
My bad.
B
'05 BMW K1200LT
'10 BMW S1000RR
Old Sep 16th, 2008, 10:24 pm   #10 (permalink)
desmolvr's Avatar
I think I will go with the Zard Top Gun full system and DP cams & ECU.
Leo Vince Cat Eliminator sloduck HyperMotard 28 Dec 5th, 2008 8:19 am
Leo Vince Cat? sloduck HyperMotard 4 May 14th, 2008 12:18 pm
For Leo Vince owners ONLY!!! 08hyper HyperMotard 17 May 7th, 2008 2:26 pm
anyone ceramic coated Leo Vince? osayek Superbikes 15 Mar 19th, 2008 1:36 pm
Need Help With Leo Vince 999 bracket thedjmongoose Superbikes 6 Mar 6th, 2008 6:07 pm
