Arrows on the Handlebar Clamp - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Sep 13th, 2008, 2:36 pm   #1 (permalink)
AXE
AXE's Avatar
What direction do the arrows on the handlebar clamp go. I have some pictures of mine before the tear down to get powdercoating done that show them towards the front wheel. I have seen pictures of others after tear down going towards the rear. The manual doesn't say, but they specify the torque sequence as 1-2-3-4-1-2 going in a backwards Z pattern from the lower left hand side of the bike when facing towards the front wheel.
I know it was discussed somewhere but couln't find the reference. I am going to do mine like my old pictures show.
Thanks!
Out!
2008 Ducati Hypermotard
Old Sep 13th, 2008, 3:23 pm   #2 (permalink)
Vdue's Avatar
the arrows are pointing to the back.
http://www.moto.dotklein.com
1198 SP '11
HYM S '08
Roughneck '07
Vdue is offline   Reply With Quote
Old Sep 13th, 2008, 4:32 pm   #3 (permalink)
HA! on mine the arrows were pointing to the front. guess it depends on which way the original assembler dude was facing...
1950 Triumph T-Bird
1954 Triumph T-Bird
1961 Triumph TR6
1969 Triumph Bonneville
1973 Triumph TR5 MX
1969 Harley FLH Shovelhead
2006 Honda CRF 250F
2008 Ducati Hyper 1100S
1969 Meyers Manx Buggy
nog00der is offline   Reply With Quote
Old Sep 13th, 2008, 4:58 pm   #4 (permalink)
GHEZZI's Avatar
Didn't the Indians allways point their arrows forward?
Me not backward Tonto!
Usually handelbar clamps (both one and two piece) have a difference in the height of the underside machined surfaces that interface with the top side of the triple clamp. On the Hyper this means with the arrows pointing forward the mating surface at the rear (don't go gay on me here) will make full contact. The front side of the clamp will have a 2mm gap when all bolts are tightened in the proper sequence you mentioned.
If you were to use the specified tightening sequence with the arrows pointing backwards, it is possible the clamp may crack or warp. So Vdue, "Don't shoot yourself"
Old Sep 14th, 2008, 6:48 pm   #5 (permalink)
mine point sideways?!?!?
Old Sep 14th, 2008, 8:46 pm   #6 (permalink)
Hypremotard's Avatar
Mine is a little to the left.....
  • '08 Hypermotard S
  • '03 Monster 800 (Gone!)
  • '98 HD Fatboy (Gone!)
  • '95 HD Road King
Hypremotard is offline   Reply With Quote
Old Sep 15th, 2008, 3:00 am   #7 (permalink)
GHEZZI's Avatar
We don't need to know such things, too much information!
Old Sep 15th, 2008, 7:21 am   #8 (permalink)
ak57's Avatar
Images: 6
one is looking back and the other one fwd
seriously ,they look back and we had this conversation at the dealers and that's the right way
Riding enjoyment means lightweight motorcycles. Weight is something of an obsession for us.- Claudio Domenicali
ak57 is offline   Reply With Quote
Old Sep 15th, 2008, 9:53 am   #9 (permalink)
MarksFriggin's Avatar
Mine point forward.
Old Sep 15th, 2008, 4:03 pm   #10 (permalink)
GHEZZI's Avatar
My experience has always been (with Jappers) that the arrows or dots have always been on the forward side of the bars, and the mating surface underneath that mounts flush with the triple clamp has also been at the front. The tightening sequence with these begins at the front.
On the Hyper with the arrows pointing forward, that mating surface is on the rear side of the bars. This fits with Ducatis tightening sequence starting with the bolts at the rear.
Always check for the finer details before disassembly, if you look at the bar mounts you can see a 2mm gap at the front edge of the clamp with ^ pointing forward.
What are the differences between a monster tripple clamp and a 998 tripple clamp? oneducs Superbikes 4 May 25th, 2008 12:03 am
handlebar top clamp ... johnchypermotard HyperMotard 19 Jan 2nd, 2008 9:06 pm
Handlebar question 99+ SS scooterqualified Supersport 3 Dec 12th, 2007 11:02 am
O B E R O N Adjustable handlebar clamp mirrors PAKBIKES Sport Classic 13 Nov 21st, 2007 11:01 am
Need help getting top triple clamp off kym53 Sport Classic 3 Feb 26th, 2007 1:28 am
