Slider questions - Ducati.ms - The Ultimate Ducati Forum
Old Sep 9th, 2008, 7:46 am   #1 (permalink)
Treadmarks's Avatar
Slider questions
Ok I don't race my hyper on the track. I commute on it daily, 30 miles one way.
I have this trick set of candy apple red skate board wheels left over from another project. I will install these as axle sliders for the front and rear.
My question is, do I want them to be able to rotate or not. I know the rear axle spins and that can make chain cleaning and maintenance when it is on the stands a beeyatch. I only have one rear stand and it is designed to lift by swing arm or sliders.
So.....to spin......or not to spin?
TREADMARKS
Ford F150 4x2 Lifted
Treadmarks is offline   Reply With Quote
Old Sep 9th, 2008, 11:01 am   #2 (permalink)
My guess would be that it doesnt matter, but you will probably have to take off the rear sliders to lift the bike with the stand.
If they spin freely, when you come to a stop you'll have a set of mini spinners on your bike
vinneyt is offline   Reply With Quote
Old Sep 9th, 2008, 4:23 pm   #3 (permalink)
Werloc's Avatar
Images: 6
I have a set of spool rear sliders and also have a double sided rear stand. The sliders do spin in the stand, but it's only a matter of time before they will wear out. I idle the bike in first gear while in the stand to lube the chain. So, that being said, try to make your sliders spin....
Werloc is offline   Reply With Quote
748 frame slider alternatives MotoDucMan Superbikes 10 Jul 24th, 2008 1:21 am
A Few 916/996 Questions, also Dealer Questions superbike81 Superbikes 6 Mar 10th, 2008 8:32 pm
New Supersport 1000DS! Questions... pldj1000 Supersport 5 Jun 2nd, 2006 3:49 pm
