Blown Fuse - Ducati.ms - The Ultimate Ducati Forum
Old Sep 8th, 2008, 5:37 pm   #1 (permalink)
MY45's Avatar
Blown Fuse
Installed the zards last week and now when i turn the key to "P" it blows the 30A fuse (in the red clip).... Any ideas?
MY45 is offline   Reply With Quote
Old Sep 8th, 2008, 6:05 pm   #2 (permalink)
hyperichie's Avatar
maybe u melted the wire? Check to see if ur brake lights still work with and with out the brake. I am interested to see what it is..
08 Ducati Hyper 1100
06 Honda CRF-88cc SM
07 Husky SMR 510 (sold)
05 Suzuki GSXR 1000 (sold)
06 Suzuki DRZ 400sm (sold)
04 Suzuki GSXR 750 (sold)
01 Yamaha R6 CLE (sold)
hyperichie is offline   Reply With Quote
Old Sep 8th, 2008, 7:07 pm   #3 (permalink)
MarksFriggin's Avatar
I remember reading a post about the Zard tail light mount (?) not being grounded correctly or something like that. There should be a thread on here about that somewhere.
Found it:
Note For Owner's With (& without) DP Luggage Rack installing Zard Penta
Old Sep 8th, 2008, 10:40 pm   #4 (permalink)
tunefx's Avatar
There was another thread where someone discovered the insulation worn off several wires in the rear section of the bike, under the red thing behind the seat. I searched but was unable to find the thread.
'08 HM 1100 S
tunefx is offline   Reply With Quote
Old Sep 8th, 2008, 10:58 pm   #5 (permalink)
AXE
AXE's Avatar
When installing my ZARDS, I shorted one of my wires during my test before I shrink wrapped them after solding the wires. I blew the same fuse, so that is the likely problem. One thing you need to watch when soldering the wires is to not get a sharp spot in the solder or it can poke through the electrical tape or shrink wrap and you are screwed. Shorts can be a bitch to find, but this one should be easy since you know where to look.
Out!
2008 Ducati Hypermotard
Old Sep 9th, 2008, 5:02 am   #6 (permalink)
MY45's Avatar
Ok so i found out it was the number plate light...the wires were on the wrong terminals, which made the + short out on the metal number plate mount. I switched them around and the - is now earthing and the fuse is fine.
But......i cant seem to get the front light to go. Im not sure how long it has been out, but the HI PASS button works but the hi/low switch has no power to it. Are there more fuses?
OK so i found the fuse box and one of the 15A fuses was out, so i swapped it and all is good now
Old Sep 9th, 2008, 7:01 am   #7 (permalink)
unfast1's Avatar
On the fuse subject.
Do any of you pull any fuses for trackdays for the lights, or do you just tape.
Just don't want the tape to bake onto my headlight.
2008 Black Hyper S
2005 CBR 1000RR
2001 CBR 929RR
1997 GSXR 600
unfast1 is offline   Reply With Quote
Old Sep 9th, 2008, 7:12 am   #8 (permalink)
MY45's Avatar
I think its the number 2 fuse 15A, just pull it and no more lights
Blown 5amp fuse Dave748s Superbikes 5 Jan 10th, 2008 12:02 am
Fuse keeps blowing. TORC Superbikes 8 Oct 22nd, 2007 3:44 am
748 Blown Fuse....Thankyou. dunlop0_1 Superbikes 1 May 25th, 2006 10:20 am
748 blown fuse part 2 dunlop0_1 Superbikes 2 May 22nd, 2006 9:27 am
748 blown fuse dunlop0_1 Superbikes 7 May 22nd, 2006 3:52 am
