Sep 8th, 2008, 8:06 am
gas tank pressure
Just curious if this happens to anybody else. When you turn your gas cap and then pull up to remove it...is there a tremendous amount of suction? When I go to take my cap off I really have to pull on it and the noise of the pressure it quite loud. Never had a bike that has done that before. Is this typical on the hyper?
Sep 8th, 2008, 8:13 am
no it's not,i would check the tubes if they are blocked in anyway
Riding enjoyment means lightweight motorcycles. Weight is something of an obsession for us.- Claudio Domenicali
Sep 8th, 2008, 8:25 am
mine did that a little when it was 100 degrees outside, but since I removed the smog canister, it has not done it since.
Sep 8th, 2008, 10:48 am
Mine does that too. I wasn't the one that took off the canister, so, I guess I should look at the routing and see if one of the lines should be unplugged.
Sep 8th, 2008, 11:20 am
Mine did it with or without the canister but it doesn't seem to be temperature related. Sometimes there's quite a bit of pressure, other times there's hardly any. It's not the same on any given day or with any temperature. Maybe the breather valve is bad?
Sep 8th, 2008, 11:23 am
No that has never happened to me. Before or after removing the canister.
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
Sep 8th, 2008, 11:27 am
not sure of the cause but I agree with Friggin Mark.
every other time it is like opening a bottle with pressure change...pffffttttt!
JCB
2010 1198
Full Termi, DP Race Seat, SpeedyMoto Clutch Cover & Plate, Pazzo Levers, EVR Clutch Slave
2008 HM-S Black (sold and miss it...)
DP Full 2-1 Termi, DP Race Seat, Pazzo Levers, Scotts Damper, MotoVation Sliders, DP Carbon Parts
Sep 8th, 2008, 3:19 pm
Home of vortex tuning
Mine does it occasionally after running a couple of minutes to the gas station, cold startup, stored in the house. I have temps over 100 here, doesn't seem related, cannister removed.
Sep 8th, 2008, 7:57 pm
Dealer checked it out. Turns out my charcoal canister was full of gas. They removed the canister and the bike runs good now. Idles seems lower than before, around 1200-1300 instead of 1250-1350. But, it's running good so I'm happy for now. Bike has been in the shop a total of 19 days so far, so hopefully it doesn't have to go back.
Sep 9th, 2008, 12:11 am
how does that happen? you always overfilling your gas tank?
