Running on 1 Cyl or 2 Plugs - Ducati.ms - The Ultimate Ducati Forum
Old Sep 7th, 2008, 3:03 pm   #1 (permalink)
tunefx's Avatar
During my ride through some mountains today I noticed my bike seemed suddenly quieter with less power. Upon pulling off the road I confirmed my exhaust note wasn't the same and it felt like the exhaust wasn't putting as much pressure out as usual.
I turned the bike off for about 20 minutes. Upon restart everything was back to normal.
My initial impression was that it was running on one cylinder. One of the more experienced guys said it sounded like only one plug on each cylinder was firing--thus meaning a plug on on each cylinder was not firing. I'm inclined to agree with his observation.
The rest of the way home everything worked perfectly fine.
The bike did not get too hot. I'm going to look for a loose wire but this was not an intermittent problem so I'm looking for other ideas.
Has this happened to anyone else?
Being new to Ducs, maybe I should be asking if this is one of those cool characteristics of a Duc! Not a complaint, I am totally in awe of the bike. Well, I would like to see better quality hardware (nuts, bolts, etc.). But I'm using that as a reason to upgrade my sockets to a full set of six-points!
'08 HM 1100 S
tunefx is offline   Reply With Quote
Old Sep 7th, 2008, 6:14 pm   #2 (permalink)
AXE
AXE's Avatar
You better check your subframe out!
Out!
2008 Ducati Hypermotard
Old Sep 8th, 2008, 6:29 am   #3 (permalink)
tunefx's Avatar
LOL AXE
I think I should have put a different title on this thread so folks would read it!
'08 HM 1100 S
Old Sep 8th, 2008, 3:51 pm   #4 (permalink)
This happened to mine. One minute it would run fine and sound great, the next it would seem down on power and the exhaust would sound flat. Finally found out that the nut that holds the two sprockets on that drives the cam belts wasn't torqued properly from the factory. They came loose and wore on the keyway enough that the timing was changing. Wore enough that I had a valve hit a piston. It was all covered under warranty but took two months.
speedfreak is offline   Reply With Quote
Old Sep 8th, 2008, 10:13 pm   #5 (permalink)
tunefx's Avatar
Off to find my tools! It certainly will not hurt to check!
Thanks for the tip!
'08 HM 1100 S
My ST3 ran out of gas and now it’s running bad VIVID1 Sport Touring 22 Aug 25th, 2008 1:57 pm
ST4S Spark Plugs st4spokane Sport Touring 13 Mar 10th, 2008 8:07 pm
916 mechanical problem -- fouling plugs not running Any Ideas? martincf Superbikes 12 Dec 26th, 2007 10:23 pm
Iridium plugs - Crap or cool fester Supersport 21 Jul 13th, 2007 4:06 am
Air/Fuel mixture & Rough Running Neil996R Superbikes 2 Mar 27th, 2007 12:15 am
