Chain adjust - Ducati.ms - The Ultimate Ducati Forum
Old Sep 6th, 2008, 6:27 pm   #1 (permalink)
unfast1's Avatar
Chain adjust
OK call me a fool.
I have tried what the manual says with the two bolts on the rear. Do I just loosen them and push the rear tire back to tighten the chain? It's not working.
First time with a single side swing arm.
2008 Black Hyper S
2005 CBR 1000RR
2001 CBR 929RR
1997 GSXR 600
unfast1 is offline   Reply With Quote
Old Sep 6th, 2008, 6:44 pm   #2 (permalink)
mountainrider's Avatar
Location: i see twisty roads..., and I like it, I Like it a lot!
Images: 11
Lots of others have asked the question. Lots of the answers have been to grab the rear chain gaurd and rotate the wheel. Even though I have the special tool, thats how I do it.
Be sure to measure from the rub block on the bottom of the swingarm as you press down on the chain just in front of the lower guide. it should be about 4 inches. Disregard the owners manual or it will be very tight.
More info available with a search.
Fresh Air, Frenetic Road, Agile Bike
.....<a href=http://www.youtube.com/watch?v=B1UYsN5u5No target=_blank>http://www.youtube.com/watch?v=B1UYsN5u5No</a>
mountainrider is offline   Reply With Quote
Old Sep 6th, 2008, 6:59 pm   #3 (permalink)
Brainfry's Avatar
Just adjusted mine today after dropping down to a 14 sprocket in the front. Works as stated.
B
Never enough garage space.
'05 BMW K1200LT
'07 BMW R1200GS Adventure
'08 Ducati Hypermotard S
'10 BMW S1000RR
Brainfry is offline   Reply With Quote
Old Sep 6th, 2008, 8:14 pm   #4 (permalink)
unfast1's Avatar
That's what I am doing. The bolts are completely loose and it's not moving.
2008 Black Hyper S
2005 CBR 1000RR
2001 CBR 929RR
1997 GSXR 600
Old Sep 6th, 2008, 8:26 pm   #5 (permalink)
Is the info on the chain tension label correct?
pic on post #13
Old Sep 6th, 2008, 8:50 pm   #6 (permalink)
unfast1's Avatar
I found that when I did a search but the damn thing will not move.
2008 Black Hyper S
2005 CBR 1000RR
2001 CBR 929RR
1997 GSXR 600
Old Sep 6th, 2008, 8:59 pm   #7 (permalink)
the rear chainguard is just gonna rotate to the rear..
if it's not moving, then the chain might be tight.
Old Sep 7th, 2008, 5:38 am   #8 (permalink)
well for a start the manual tells you to take it to a dealer!
The rear hub is eccentric-so you move it one way (toward front of bike ) and it loosens and t'other way , the opposite.
You can get special 'C' spanners on ebay or just gently hit the adjuster with screwdriver/hammer.to see the adjuster you really need to look at the rear hub from underneath.looks like the spring retainer on the rear shock.
chain tension seems to be unresolved- the sticker on the swingarm is about 50% that which is in the workshop manual. prolly better a bit looser than too tight.
Old Sep 7th, 2008, 6:58 am   #9 (permalink)
zvez's Avatar
I've got one of these:
http://cgi.ebay.com/ebaymotors/DUCAT...=p4506.c0.m245
Doesn't your toolkit have a chain adjuster in it that you got with the bike?
Chris
12 1199 Panigale......May 26th.....May 30th?????????
10 Ducati Streetfighter
2011 Aprilia RSV4-R APRC
05 Goldwing
zvez is online now   Reply With Quote
Old Sep 7th, 2008, 12:39 pm   #10 (permalink)
Treadmarks's Avatar
Originally Posted by Quackzilla View Post
Thanks for that post Quack!
I did my second oil change and chain adjust today. I tried to adjust last week, but couldn't figure it out. Back off the pinch bolts then rotate the chain guard. Too easy.
TREADMARKS
Ford F150 4x2 Lifted
Treadmarks is offline   Reply With Quote
Chain Cleaning, Waxing and WD-40 Shazaam Hall of Wisdom 41 May 9th, 2012 4:11 pm
Chain Inspection and Freeplay Adjustment Shazaam Hall of Wisdom 1 Jan 10th, 2012 11:41 am
Chains and oiling duckbrand Superbikes 31 Mar 21st, 2008 2:33 am
999s Gearing Change Soarer Superbikes 8 Jul 18th, 2007 10:45 am
