Originally Posted by lelenb
There is a difference because of the larger diameter piston the aftermarket slave cylinders don't push the actuator rod as far when you pull in the clutch there fore it does not have as far to return.
With the stock clutch lever and clutch springs the Hyper's clutch was pretty light. I installed the shorty Pazzo levers and it was a bit firm but not bad. I then installed Speedymoto stainless springs with my open cover and damn that is a heavy clutch. An aftermarket slave cylinder is high on my list of must do's.
What lelenb said is true, the bigger piston in the slave cylinder will move a
"shorter" distance given the same amount of fluid from the clutch lever
when you pull it in, thus giving a "lighter" pull, and because the clutch pack
does not separate as far as stock, the clutch will engage a little sooner.
The reason the factory does not install the 30mm slave is because of the
MFG tolerences in the clutch plates, to give a little extra "clearance" so the
clutch acts right on production bikes.
There are companies that have 32mm slave cylinders for a even lighter pull,
but then the clutch stack height has to be "PERFECT" for it to work right, because
there will be no extra clearance, and can result in hard to find neturals, and
notchey shifting.
I have seen many bikes with the shortie clutch levers and the stock slave,
and for me making the clutch too stiff, I think they will be better off to run
the 30mm slave with the short levers, or go with the longer levers
IMHO, Aloha Alex
