Rear Brake Lever hard to reach??? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Aug 27th, 2008, 3:00 pm   #1 (permalink)
bmartinek's Avatar
So after a couple weeks now I have found the Rear brake lever is a bit hard to reach when I am wearing Sidi Riding boots, but it is fine with just my regular shoes.
I wish I could get a lever that would stick out more , but that means it would just drag more.
Anybody else have this problem?
Anybody have a solution???
08' HyperMotard- Quat-D Full Exhaust System, DP ECU, Blinged Clutch, DP WindScreen, DP Comfort Seat, err and some sliders...
bmartinek is offline   Reply With Quote
Old Aug 27th, 2008, 3:08 pm   #2 (permalink)
booyakasha!
aeolian's Avatar
Images: 6
When I rode demos and Lumpy's motard, I found that the rear brake foot lever was waaaay forward. For me, at least.
I'm wearing Alpinestars SMX-4.
aeolian is offline   Reply With Quote
Old Aug 27th, 2008, 3:12 pm   #3 (permalink)
bromike666's Avatar
The Hypermotard has a rear brake?
"I love the sound of a dry clutch in the morning"
10 F1098S Streetfighter
08 Hypermotard 1100S
08 Multistrada 1100S
07 SM610
bromike666 is offline   Reply With Quote
Old Aug 27th, 2008, 3:26 pm   #4 (permalink)
bmartinek's Avatar
'course it has a rear brake! Thats what makes it so much fun slide sideways to a stop light.
That is if you can find it behind the clutch cover.
Old Aug 27th, 2008, 3:29 pm   #5 (permalink)
Flavor of the Month
Bravo51's Avatar
Images: 3
I find the rear brake to be a little too good when I come off the 748. I've locked up the rear on the hyper a couple times now....I may be the only one to wish it was softer.
Sam 'MF' Brandt
2000 Ducati 748
2006 Yamaha YZ450F (SCARY!)
2008 Suzuki DRZ-70 pit bike
2008 Ducati HyperMotard S
Bravo51 is offline   Reply With Quote
Old Aug 27th, 2008, 3:30 pm   #6 (permalink)
Home of vortex tuning
CDONA's Avatar
I use mine to keep from smashing my tail light. Reminds me to ride the hyper with my dirt boots for control issues too.
Old Aug 27th, 2008, 4:29 pm   #7 (permalink)
bmartinek's Avatar
Nice...
Yeah I need to adjust my shifter for my boots as well. Way too low...
Old Aug 27th, 2008, 7:58 pm   #8 (permalink)
GHEZZI's Avatar
Day one on my Hyper I had to lower or rotate the hand controls forward, but raise the the foot levers. It is possible the foot controls were set to use with no rubber tops on the footpegs.
With regard to the foot brake lever and it's height adjustment, the bolt and lock nut were fitted from the top. I first removed the lock nut and fitted it from the bottom side, lever still too low.
I then fitted a short bolt and lock nut, all from underneath so the end of the bolt is flush with the top surface of it's mounting platform. The hole needs to be plugged as the stop light actuating pin lines up with the hole.
The initial height for foot contact was good but it had way to much freeplay and travel to work with my ancient inflexible ankle, so .............
When ever you adjust the pedal height, attention needs to be paid to the freeplay at the master cylinder, the vertical arm from the lever heel that passes thru the rubber boot into the master cylinder needs to have a few thou' clearance to the back of the piston, (not a few mm).
Old Aug 27th, 2008, 8:10 pm   #9 (permalink)
Duc ... Duc ... GOOSE!
Da_Bull's Avatar
Like Ghezzi said - remove the rubbers from the footpegs. It makes ALL the difference.
PS: I find myself using my rear brake A LOT on this bike ... so much fun.
-Marco
Da_Bull is offline   Reply With Quote
Old Aug 27th, 2008, 10:06 pm   #10 (permalink)
hyprduc's Avatar
Dirt Tracker
hyprduc is offline   Reply With Quote
800ss torque specs Reed-0 Supersport 2 Dec 17th, 2007 3:50 pm
99 748 Rear Brake Heat Problem arandazz Superbikes 2 Jun 8th, 2007 1:33 pm
Need a rear brake lever ny749 Superbikes 3 Feb 15th, 2007 10:06 pm
Rear Brake on a 2002 748.... Mirek Superbikes 9 Aug 5th, 2006 9:12 pm
