Can Someone Explain Exhaust Valve? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Aug 27th, 2008, 8:45 am   #1 (permalink)
Ok the exhaust valve just before the mufflers... Is this like an Ex-Up valve on a Yamaha where regulates the backpressure for more low-end snap? If so does anyone know what RPM it works at? My HYM-S seems to bobble and run like shit below 3000RPM and I wonder if that is when this valve opens/closes. All full aftermarket exhaust seem to remove this valve and I assume the aftermarket ECUs disable its function. Without the valve to regulate I wondered if the bikes ran even worse at low RPM around town/traffic/granny riders or the ECUs accounted for this and you never miss the valve.
Thanks for your time.
JAWS
Jaws525 is offline   Reply With Quote
Old Aug 27th, 2008, 8:56 am   #2 (permalink)
it's used for meeting european sound restrictions.
Old Aug 27th, 2008, 1:16 pm   #3 (permalink)
georound's Avatar
I remember reading that it was closed for sound at low rpm and opens above that point. Unlike the exup which varies incrementally depending on rpm.
Old Aug 27th, 2008, 3:31 pm   #4 (permalink)
Flavor of the Month
Bravo51's Avatar
Images: 3
I was told once, but I may have messed this up.....it opens at 3000rpm or when in gear....for sound baffling only.
Sam 'MF' Brandt
2000 Ducati 748
2006 Yamaha YZ450F (SCARY!)
2008 Suzuki DRZ-70 pit bike
2008 Ducati HyperMotard S
Bravo51 is offline   Reply With Quote
Old Aug 27th, 2008, 3:35 pm   #5 (permalink)
Home of vortex tuning
CDONA's Avatar
My guess it operates as stated from the fine print on the mufflers. But only when there is a value indicated on the speedometer.
Old Aug 27th, 2008, 8:28 pm   #6 (permalink)
GHEZZI's Avatar
It remains 'open' when the engine is off. Take your seat off and turn on the key, you will see and hear the valve sweep thru it's arc to 'closed' then 'open' again.
This device has been installed at the factory primarily to meet various Govt noise restrictions. If you look at it in reverse, it has been developed for power, I shall explain.
The legislation is basically speed specific in its wording. If the noise control was handled by fixed or permanent baffles in the exhaust system it would restrict performance at other speeds.
In the past some manufacturers have used excessively high final gearing ratios so the bike would pass the noise test by using very low RPM's. That makes the bike a pain in the proverbial .... to ride in the real world. First gear can be too high for idleing along in traffic, or drag racing/wheelies. Top gear can be too high to use at legal h'way speed.
HD did this. To alter the gearing for toothed belt final drive can get expensive, Moto Guzzi differential replacement was even worse. My Cali would get the same economy in both 4th and 5th gear cruising at 115kph, the 600rpm difference meant that in 4th gear at 3700rpm the motor felt a lot smoother. Also, acceleration was greatly improved because the motor was higher in it's torque curve instead of labouring.
So our little device closes up when it needs to, so your EPA boffins don't have aperplexi. WOFTAM (waste of flamin time and money) coz we throw it all in the bin and fit what our bikes need, NOISE!
The surging you experience is more related to the lean mixture of 14.7:1 air/fuel ratio our bikes are set at with the narrow band O2 sensor. The sensor has a major influence on the way our bikes behave/perform below 4500rpm or less than 25% throttle.
See Possible solution to reduce surging & poor throttle response?
Old Aug 27th, 2008, 10:23 pm   #7 (permalink)
infidel's Avatar
When did you get so smart Ghezzi?
Hypermotard 1100S
Aprilia SXV550
Aprilia RS250
Suzuki RGV250
Old Aug 31st, 2008, 3:42 pm   #8 (permalink)
GHEZZI's Avatar
I don't have a life, so for my entire 'social needs' I surf this damn forum. I feel like I'm goin down hill fast but ocassionally I learn something new
749R exhaust questions Movi Superbikes 11 Aug 27th, 2008 4:45 am
Valve Adjustment: making sense of the numbers DucS1k Sport Classic 4 Apr 30th, 2008 2:12 pm
Exhaust Valve, what is it really for??? 08hyper HyperMotard 8 Sep 13th, 2007 12:57 pm
How important is the ecu and exhaust valve replacement on the '04 ST3? Greerzilla Sport Touring 8 Aug 15th, 2007 4:08 pm
916 track bike pics, exhaust leak ducatimike Superbikes 11 Apr 7th, 2007 8:52 pm
