418 LBS wet - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com Classifieds!
Old Aug 26th, 2008, 3:22 am   #1 (permalink)
418 LBS wet
I weighed my bike at work yesterday. It was 412lbs. I burn less than a gallon on the way to work so 418 lbs is a pretty close figure on what I burn on the commute every day.
That's with a full Termi and the rear foot peg brackets removed.
Just thought I would share
Alpinist
Alpinist is offline   Reply With Quote
Old Aug 26th, 2008, 8:43 am   #2 (permalink)
Enigma's Avatar
i weighed mine also it said 408, i was kinda disappointed, same mods as you
Enigma is offline   Reply With Quote
Old Aug 26th, 2008, 8:48 am   #3 (permalink)
acesanugal's Avatar
396 here. On a digital postal scale calibrated monthly. Termi2:1 carbon, Pro-Taper bars, handguard/mirror/blinkers removed - CRG lane splitter installed with small LED blinkers, no passenger peg assemblies, emissions canister removed.
And it's an "S" - if that matters...
acesanugal is offline   Reply With Quote
Old Aug 26th, 2008, 10:04 am   #4 (permalink)
hyprduc's Avatar
Wow, you guys scared me for a second. I saw the title of the thread and thought you were into big girls!
Anyway, whatever my Hyper weighs, it's still flicjable and fun
Cheers
hyprduc is offline   Reply With Quote
Old Aug 26th, 2008, 10:07 pm   #5 (permalink)
That's a good one, made me laugh a little.
Guess I realy have to put my ride on the scale once, wonder how low she will come in with half a ton of carbon on it
www.Shift-Tech-Carbon.com
Shift-Tech-Carbon Performance- High Quality Carbon Products!
Shift-Tech is offline   Reply With Quote
Old Aug 27th, 2008, 1:44 am   #6 (permalink)
bmartinek's Avatar
Yep that "S" should matter to about the tune of about 5 lbs.
BTW acesanugal, where did you get the turnsignal bracket for your front-signals? I am dying to take the hand-guards off my set up.
08' HyperMotard- Quat-D Full Exhaust System, DP ECU, Blinged Clutch, DP WindScreen, DP Comfort Seat, err and some sliders...
bmartinek is offline   Reply With Quote
Getting the spring rate right YellowDuck Sport Classic 25 Apr 9th, 2011 8:11 pm
2006 800SS Wet Clutch Noise and Thump betabit Supersport 6 Apr 11th, 2010 1:46 pm
Wet / Dry Clutch AAL Sport Classic 7 Jun 9th, 2008 1:04 am
Clutch plates for wet clutch? portisroads Sport Classic 0 Mar 23rd, 2008 9:30 am
Synthetic Oils and Wet Clutches ILUVMYDUC Sport Classic 18 Mar 12th, 2008 5:44 pm
