Aug 25th, 2008, 9:17 am
Possible solution to reduce surging & poor throttle response?
I'm in the process of gathering test data on a solution to reduce surging; poor throttle response, etc. when the stock ECU operates in closed loop mode. Please see my post in the Sport Classic section. This potentially could help HyperMotard owners as Ducati uses the same narrow band oxygen sensor.
Better Throttle Response, Less Surging and Popping? - Clike Here
I'm on day 3 of testing the plug & play adapter on my bike with favorable success. Thanks.
Aug 25th, 2008, 10:13 am
The issue is that most of the bikes have some form of modification, most of which eliminate the o2 sensor entirely and run the bike open-loop. The best fix seems to be a power commander and someone who knows how to tune it for your individual bike setup.
Aug 25th, 2008, 10:31 am
I agree 100%. I'd love to have the DP ECU with a Power Commander and custom map, but I'm not ready to spend $2k to get it done. We actual have a very good Ducati tech in the Milwaukee area @ Corse Superbikes and supposedly he can make PCIIIs run without the DP ECU and no check engine light. The O2 manipulator adapter would be best for stock & lightly modified bikes. I'm running Staintune slip on mufflers & an updated closed loop ECU.
Aug 25th, 2008, 1:16 pm
jborders5,
I read that and found it interesting, actually started working on my own and then found a deal on a DP ECU. Do you have the VDST? It would be interesting to see the pulse width change at idle and how far it can go (wider pulse or richer) without throwing a code.
The trick to making a PCIII or any other open loop fuel management device work with the stock ECU is to first acheive stability in the control loop. The lambda signal has to be emulated in a way that simulates a relatvely constant AFR so there is little to no correction. It can be lean, it doesn't matter as your going to correct that.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Sep 11th, 2008, 8:56 am
Anyone try this on their Hyper yet?
Current Rides:
2008 Ducati Hypermotard 1100
2006 Kawasaki KLX250S
2004 Honda CBR600RR
2002 BMW R1150R
1996 Ducati 900SS/CR
Sep 11th, 2008, 10:19 am
Yes I gave one a go but with it fitted the engine only runs for a few seconds then wont even fire, the guy making them is very good to deal with and is working on the problem, I think they have been successful on other models so hopefully he can get over the problem with the Hyper, if you send him a PM he is very quick to answer
Sep 12th, 2008, 11:03 am
Thanks krill!  Yes he seemed to have had very good results with the other Ducs. I hope he gets it straightened out on the Hyper soon.
Current Rides:
2004 Honda CBR600RR
2002 BMW R1150R
Sep 13th, 2008, 5:41 am
Location: i see twisty roads..., and I like it, I Like it a lot!
Ghezzi seems to have had some luck with his
O2 Sensor Manipulator
Fresh Air, Frenetic Road, Agile Bike .....
Sep 13th, 2008, 8:37 am
Please disregard my last posting, it seems I was trying to fit it in the wrong place, if you get one it's not the wiring under the seat though the plug and socket are the same, my mistake for foolishly taking things for granted
Sep 13th, 2008, 9:45 am
Just pre-ordered one.
Now I just need to order cat eliminator before wife cancels credit cards.
TREADMARKS
Ford F150 4x2 Lifted
