Mountainrider, I do not want to explore YOUR fork with you
, but I can share anothers experience.
One of my local suspension Guru's removed a spring (from my fork) and commented that the taper would technically give it a progressive action, but the variation in diameter is such that it would feel closer to a linear spring in action.
He measured the Hyper spring against known products and in his opinion would rate it very close to .80kg/whatevers, (I can never remember, cm or mm).
The reason for the taper is more likely to just keep the spring centered in the fork to stop it wearing the inner surface of the outer fork tube.
With the sealed cartridges, he has previous experience of cutting the bottom crimp off, and machining a new end and silver soldering it back on. This end has a circlip groove on the inside which locates a plug that is threaded in the centre for the bottom cap screw that holds the lot together.
There is one problem that could arise. The piston that holds the shim stack could be an odd size which means Race Tech would not have a replacement. Re shimming may be of limited value, however we could always machine our own piston, ....................... development time and cost could be excessive. Once the original cartridge has been cut its fate is sealed, there is no going back.
Call Scottyspeedshop and see if he will donate his original cartridges to science.
