DP Flywheel - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com
Motorcycle.com
Old Aug 21st, 2008, 10:28 am   #1 (permalink)
DP Flywheel
i don't have a LW flywheel yet, and will most likely go with the Nichols, but found this of interest.
i've read that some people that bought/installed the DP flywheel needed to have it machined in order to work. I had emailed a question to SSR (who makes a LW flywheel) to see if there's would fit the HM. Here's the reply that i recieved:
"We checked the ducati catalog, the hypermotard part number is 276.1.025.1C, our flywheel fits the 276.1.025.1B for sure. please check with your ducati
dealer for the fitment."
so for those of you that have had fitment issues, do you know which flywheel you recieved/used?
Old Aug 21st, 2008, 10:32 am   #2 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Nichols... no guesswork or screwing around with machining.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Aug 21st, 2008, 10:34 am   #3 (permalink)
i know that, the Nichols is lighter, less expensive, and fits
Old Aug 21st, 2008, 11:20 am   #4 (permalink)
parkcrf's Avatar
The DP flywheel has to be machined to fit. I just went through this, my bike is in the shop now and they had to have it machined so it would fit against the starter gear. Picking it up today - will report on the difference
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old Aug 21st, 2008, 11:42 am   #5 (permalink)
i know that you had to get it machined to fit, the question is which part did you recieve/use
276.1.025.1C is the for the HM
276.1.025.1B is for the others
not sure on Ducati's numbering, but does the letter represent a change to the part?
Old Aug 21st, 2008, 2:08 pm   #6 (permalink)
Performance Center
Ducshop's Avatar
Or you can machine your stock one down from around 5 pounds down to 1.9 pounds ($75 exchange or have done locally) and no aluminun splines to worry about, I have seen more than a few aluminum splines striped on the crank so the starter sprag just spins then your bike wont start and aluminum flakes are in your oil.
Since the starter sprag and rotor are bolted to the flywheel it is more than just a weight. We often leave street bike flywheels a little heavier (3 lbs.) to leave some flywheel effect, about where the stock 848 is. 2C
Old Aug 21st, 2008, 3:17 pm   #7 (permalink)
Lumpy Idol's Avatar
Images: 21
Why not just leave the guesswork and go with the Nichols? It's 9oz, takes about 20 minutes to install and you can just forget about it...
The issue with the splines was with the early motors. They don't have a problem any more.
And, it revs so nice. I wish there was one lighter......
Lumpy Idol is offline   Reply With Quote
Old Aug 21st, 2008, 8:56 pm   #8 (permalink)
SquireSCA's Avatar
20 minutes to install the flywheel?
Where are the instructions? Is this something that the average Joe can do in his garage?
SquireSCA is offline   Reply With Quote
Old Aug 21st, 2008, 9:13 pm   #9 (permalink)
Duc ... Duc ... GOOSE!
Da_Bull's Avatar
I ask this question with all due respect to your shop and your shop's reputation:
Are you saying that the Nichols flywheel has a tendency to strip the splines? Or are you saying the DP flywheel - that has to be machined to fit - has a tendency to strip the splines?
I recieved a Nichols flywheel for my 916 and it weighed NOTHING. I returned it unused because I got the Hyper, and the one that came for the Hyper was far heavier than the one for the 916. However, both appeared to be machined out of rugged, billet aluminum stock ... not some soft, play-doh aluminum. Please expound on the differences between machining the stock flywheel and going with a Nichols alternative.
-Marco
Da_Bull is offline   Reply With Quote
Old Aug 21st, 2008, 11:56 pm   #10 (permalink)
Lumpy Idol's Avatar
Images: 21
No not average..
you need the puller. most shops charge 1 hour of labor which is totally worth it.
Lightweight Flywheel - Pros and Cons Shazaam Hall of Wisdom 30 Dec 13th, 2010 9:24 am
Nichol's Lightweight Flywheel - First Impression h2onoo HyperMotard 35 Jan 2nd, 2009 4:56 pm
New flywheel - won't start spikedlemon Supersport 6 Jul 13th, 2008 8:36 pm
Flywheel weight reduction program dietrichpfeifer Sport Classic 32 Jun 8th, 2008 11:07 am
Flywheel Retaining Nut Issues PAKBIKES Sport Classic 15 Feb 19th, 2008 10:22 am
