Originally Posted by Lumpy Idol
Trying to find if anyone with cams has actually degreed the lobe centers?
Post your findings if you would please.....
108 degrees intake center lobe seems to be the recommended spec for the DP cams per Bruce Meyers famed Ducati tuner.
Haven't installed my DP cams yet but I will set them up at this spec to start with. While you're in the valve train, you might want to get some MBP valve collets. These will lengthen the time between valve adjustments.
