So, how much difference? - Ducati.ms - The Ultimate Ducati Forum
Old Aug 18th, 2008, 8:40 pm   #1 (permalink)
SquireSCA's Avatar
I have an '08 Tard standard model. Zard Top Gun slipons, airbox mod, DP ECU, 14T sprocket.
I am considering the following:
DP race cams with the corresponding ECU
Zard header system to make exhaust a full kit
Power Commander and custom dyno map
I plan to do everything at once. Would the Beast R intake make an appreciable difference at that point?
And just how much of a gain do you think I will see, over what I have already done? Is it an incremental increase, or will it be very noticeable?
Anyone that has gone from my config to the above config, I would love to hear your experience on this...
Thanks!
SquireSCA is offline   Reply With Quote
Old Aug 19th, 2008, 10:02 pm   #2 (permalink)
08hyper's Avatar
Thumbs up
3 to 5 HP increase on TOP-END, I'm told, also depends on your exhaust set-up. Will pull stronger on top.
Aloha Alex
Old Aug 19th, 2008, 10:04 pm   #3 (permalink)
SquireSCA's Avatar
Aloha Alex
That's it? By going to the new cams, converting the slipon exhaust to a full system, and a PCIII with custom map, yields only about 3-5hp?
Hmmm....
Old Aug 19th, 2008, 10:19 pm   #4 (permalink)
08hyper's Avatar
NO......... After the mods, with just the TPO Beast intakes, the whole performance package
over the stock bike will net you 12 to 18HP increase, which is not too bad for a 1078CC 2 valve motor. Aloha Alex
Old Aug 19th, 2008, 10:37 pm   #5 (permalink)
Do the pistons and get heads ported then your in.
lugger is offline   Reply With Quote
Old Aug 19th, 2008, 10:39 pm   #6 (permalink)
Hmmm....
it looks like you were asking specifically what the Beast R would do in addition to having done the other mods previously. does that make sense?
1950 Triumph T-Bird
1954 Triumph T-Bird
1961 Triumph TR6
1969 Triumph Bonneville
1973 Triumph TR5 MX
1969 Harley FLH Shovelhead
2006 Honda CRF 250F
2008 Ducati Hyper 1100S
1969 Meyers Manx Buggy
nog00der is offline   Reply With Quote
Old Aug 20th, 2008, 12:51 am   #7 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
If you're going to install the cams, you might want to think about getting some H/C pistons. The pistons will help maintain torque off the bottom while the cams will provide a nice boost from mid to top. A little head work wouldn't hurt either. The Beast R will not only provide a couple of HP in the mid/upper range but will also boost low end torque and flatten the torque curve.
The stock airbox is a bottleneck to creating more power even with a stock engine. I would do the Beast R first, along with the Nichols flywheel, PC and DP ECU. Then you can decide if you still need the cams, etc.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Aug 20th, 2008, 7:49 am   #8 (permalink)
i have been told that with ducati you do not install a power commander with exhaust. if you replace the ecu, then you are fine! check with your local mechanic. i have only heard through the grape vine.
93Octane is offline   Reply With Quote
Old Aug 21st, 2008, 9:38 am   #9 (permalink)
Performance Center
Ducshop's Avatar
Thanks!
Hi, we are in Marietta if you want to come by and see our new veocity stacks, they make the most HP in the upper midrange and peak HP and will be about $100 less for the kit than the ones we tested against. Either way you should be between 98 and 104HP with HC Pistal's, cams, stacks, pipe and mapping. We are a Dynojet tuning center also.
We will have the kit on our store soon but are installing them now.
Mark
Old Aug 21st, 2008, 1:21 pm   #10 (permalink)
hi mark intrested in the stacks any chance of some photos or stats to back up your claims also who did you compere with........dyno sheets would be use full. steve
glixer is offline   Reply With Quote
Riding position difference btn SS, ST, & Monster JimiThing Ducati Motorcycle Chat 6 May 14th, 2008 6:01 pm
Difference Between 99 and 00 Performance ECUs? ProfessorX Supersport 2 Nov 19th, 2007 3:12 pm
Difference between 748 models? 18187 Superbikes 1 Aug 19th, 2007 5:14 am
difference between 999 & 749 stef_pen Superbikes 1 Jul 20th, 2007 9:24 am
5HP difference between 749 & 749R? John Superbikes 15 Feb 24th, 2006 10:09 pm
