Feel the Heat - Ducati.ms - The Ultimate Ducati Forum
Old Aug 18th, 2008, 5:45 pm   #1 (permalink)
Road Scholar's Avatar
Feel the Heat
Before I ride and just after I dismount I do a "look-over", sometimes a "feel-over" to make sure that all the parts I started with are still with me. Ducati makes liberal use of various Loc-Tight products for a reason.
Any way...
My eye is, invariably, drawn to the horizontal cylinders' intake cover where the ecu's temp sensor is located, FUGLY!
Not being an engineer, and usually getting burned when I attempt to play one, I'm wondering what would happen if that ugly sensor was relocated to the vertical cylinder?? I could intuit that more heat might live there, so would that provide more fuel? Too much fuel?
Anyone try this, wonder the same thing?
RS
Only Rich People Can Afford Poor Quality
Road Scholar is offline   Reply With Quote
Old Aug 18th, 2008, 5:54 pm   #2 (permalink)
You can't see the sensor when you're riding the bike...
Old Aug 18th, 2008, 6:01 pm   #3 (permalink)
Monstaman's Avatar
Seems like a whole lot for not a lot.
Resistance wise it should not make any difference to the operation of the sender unless it go over-hot and leaned it out too much.
Maybe the better trick would be to hang it somewhere cooler so it keeps the fueling up .... Dutchmans PC111
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Aug 18th, 2008, 6:21 pm   #4 (permalink)
Failure to mention...
I have the DP ecu that came with the full Termi I installed. Clearly the ecu will "hose down" a hot engine. Runs open loop, not sure where it now takes mission critical data from.
Maybe relocate it to the vertical exhaust position?
And, yes, I don't see it when I ride (mostly because I'm too busy trying to stay on), neither do you, but you will now, when you look over your mount prior to riding or after dismounting...gotcha!
RS
Old Aug 18th, 2008, 6:32 pm   #5 (permalink)
Monstaman's Avatar
RS
Target fixation now we will ALL get concerned about it
Cheers KTiMpostor
Monstaman
Old Aug 18th, 2008, 8:40 pm   #6 (permalink)
lelenb's Avatar
Images: 12
The flaking paint on mine draws the eye away from the sensor.
Lelen
Hyper S
Old Aug 18th, 2008, 10:13 pm   #7 (permalink)
Lumpy Idol's Avatar
Images: 21
What I wondered about was to put in a variable resistor of sorts to trick the computer into more fuel?
A manual boost controller for the DS??
Lumpy Idol is offline   Reply With Quote
Old Aug 18th, 2008, 11:05 pm   #8 (permalink)
Monstaman's Avatar
I tried it with a standard resistor on my MH900e I think it was 28 ohms from memory but to no avail, could not get it to run correctly because of the variable resistance within the sender unit.
It would be interesting to see if you could plug the rocker cover and hang the sender elsewhere although it does rely on an earth so that would need to be taken care of.
Cheers KTiMpostor
Monstaman
Old Aug 19th, 2008, 2:47 am   #9 (permalink)
Senior Moment
Buckelew's Avatar
I think that was covered in Queer Eye for the Ducati Guy, Season 2, episode #5.
I hope you have a DP Comfort seat so that your partner doesn't have to deal with you having a sore Mangina......
Buckelew is offline   Reply With Quote
Old Sep 17th, 2008, 8:16 pm   #10 (permalink)
Caidly's Avatar
Talking
...I'm wondering what would happen if that ugly sensor was relocated to the vertical cylinder??
RS
If you do a wheelie the horizontal cylinder will be vertical.
if you need to know... ask...
Ducati Electrical Problems Explained JEC Hall of Wisdom 17 May 13th, 2012 11:24 am
i figured out whats wrong with the extreme heat coming off my bike CFlan423 Superbikes 13 Aug 3rd, 2008 11:19 am
1098 Owners: Are you happy with the front end feel? koolio Superbikes 17 Jun 8th, 2008 1:32 pm
Controlling HEAT?? sfyamr1 Supersport 8 May 1st, 2007 2:35 pm
Header Heat Wrap Damage hogrocket Superbikes 56 Mar 31st, 2007 7:20 am
