squeeky brakes - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Aug 16th, 2008, 11:48 am   #1 (permalink)
squeeky brakes
Just before the bike stops the front brakes vibrate and make a loud noise, I cannot find anything wrong with them, the discs, calipers, caliper brackets, the pads dont move the discs relative to the calipers when the bike is tested at a standstill, and the bike has a very 'hard lever' with no sponginess which can mean pads/ calipers are not square to discs, I have pulled pads out and scuffed them on concrete to no avail I have checked the pucks are free??????anybody?? Breakout
Stock 2001 996r
Modified 996R.
Stock 998R
Modified 998r
Stock 2002 748R
Hypermotard S
Restored Ex Shakey Highland Springs No8 998RS,BSB 2002
Nice 998RS built from Renegade parts
998RS built from parts
2x 998RSF02 both #4 Monster Mob bikes, 2003 BSB title winning
998RS Steve Hislop Title BSB 2002
F01 Troy Bayliss Title WSB 2001
Any body wanting or needing RS parts please contact me; +61 408911001
breakout is offline   Reply With Quote
Old Aug 16th, 2008, 12:27 pm   #2 (permalink)
lelenb's Avatar
Images: 12
You squeaky front brakes are most likely just your carbon fiber front fender resonating. Put a rubber washer between it and the mounting posts and your noise should go away. Flick your front fender with your finger and listen to it rattle.
Lelen
Hyper S
Old Aug 16th, 2008, 1:25 pm   #3 (permalink)
georound's Avatar
I tried the rubber grommet between the fender and mount point...that didn't work for me at all. I complained to my dealer and they resurfaced the pads (sandpaper) and the noise went away for about 10-15 stops and then it came back. I'm tempted to try different brake pads to see if it's the pad material. Heard that Brembo has a different compound that is quieter...
Old Aug 16th, 2008, 1:33 pm   #4 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Try scrubbing your rotors with some brake cleaner and scotch pad to remove residue.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Aug 16th, 2008, 5:52 pm   #5 (permalink)
Most brake squealing is caused by a high frequency vibration of the brake pads. Clean everything as mentioned above but put a thin coat of RTV on the back of the pads. This will dampen the vibration. You can buy specialized products at any auto parts store but the cheap stuff worked for me on my rear brake.
pops65 is online now   Reply With Quote
Old Aug 16th, 2008, 8:48 pm   #6 (permalink)
georound's Avatar
That's a great suggestion....my modification time has been spent on levers and clutch mods.
Old Aug 16th, 2008, 9:18 pm   #7 (permalink)
unfast1's Avatar
It happens with the Hyper front and 696 rear. All covered under warranty. Expect a month for pads to come from Italy.
Same thing with my bike.
2008 Black Hyper S
2005 CBR 1000RR
2001 CBR 929RR
1997 GSXR 600
unfast1 is offline   Reply With Quote
Old Aug 17th, 2008, 3:38 pm   #8 (permalink)
Mine still does it with different pads and the front fender off. I`m gonna try that stuff for the back of the pads.
85' Yamaha RZ350
06' MV Agusta Brutale 910s
07' Triumph Daytona 675
08' Ducati Hypermotard 1100
frique is offline   Reply With Quote
Old Aug 18th, 2008, 12:51 am   #9 (permalink)
bmartinek's Avatar
I used to have this issue on my 749 when the pads were cold in the morning along with shuddering. I changed over to EBC-Green pads (I think) and it went away. I don't think the stock Ducati pads are so hot.
08' HyperMotard- Quat-D Full Exhaust System, DP ECU, Blinged Clutch, DP WindScreen, DP Comfort Seat, err and some sliders...
bmartinek is offline   Reply With Quote
Ah, Brakes at Last! DUCeditor Sport Classic 6 Jun 20th, 2008 6:27 pm
How to check front brakes for warped-ness? number9 Supersport 19 Feb 23rd, 2008 3:30 am
My rear brakes are fixed lubricity Superbikes 4 Feb 13th, 2007 7:32 am
Ducati brakes suck! Ldogdotcom Superbikes 22 Jan 16th, 2007 6:28 pm
999 rear brakes don't do much ? SpiderSense Superbikes 39 Dec 26th, 2006 3:39 pm
