Aug 15th, 2008, 5:42 pm
Lighter Flywheels & Slipper Clutches
Okay, Folks.
Here's a couple of questions I hope the collective wisdom of the board won't mind offereing their thoughts, suggestions, and opinions on...
1.) Lightened Flywheels - specifically, what brand, weight, etc. do you most recommend or use, and why?
2.) Slipper Clutches - same question - What do you use or recommend, and why? But add to that, any further recommendations on clutch plates, friction materials, specific springs, bolts, retainers, spring stabilizers, etc.?
Also, any other advice, suggestions, do's, don't's, good or bad experiences, etc. would be greatly appreciated.
Thanks!
Dallara
Aug 15th, 2008, 5:50 pm
Don't have a slipper clutch, but flywheel -- Nichols. Period.
It is amazing they don't come factory with these flywheels.
Beautifully made, fit / finish 11/10.
The stock flywheel feels like an antiquated piece of unnecessary metal.
Aug 15th, 2008, 6:08 pm
If you're in the market for a slipper and your budget allows, then I recommend the Suter Racing clutch. It's by far the best you can get and in the long run it turns out to be cost effective too! I would also suggest you match it with a 48T clutch basket and sintered plates, this combo is IMHO the best.
Check them here: http://www.suterclutch.com
N3R Team #166
DP: Full Termi 57mm+filter+ecu, belt rollers, racing seat, monoposto tail, rear hugger, rear sprocket, ram-air covers, keyguard, carbon fuel cap, titanium reservoir covers, billet clutch & sprocket covers, monoposto subframe, MBP collets,STM: 48T clutch basket & plates, clutch slave cylinder, Suter Racing slipper clutch, Öhlins: forks+shock+steering damper, BrakeTech iron rotors f/r, R&G sliders f/r, ValterMoto rear axle sliders, SpeedyMoto: under-body sliders & water pump cover, Samco hoses, AFAM X-ring chain, Fabbri screen, Evoluzione throttle, PT levers, Marchesini forged mag rims, Woodcraft clipons, ProGrip's, FrenTubo kevlar lines f/r, Rider's Racing rear caliper bracket
Aug 15th, 2008, 7:17 pm
I've installed a Corse 4-spring slipper clutch in a Hypermotard S along with STM slave cylinder and springs lighter than the supplied Corse red springs. This clutch is like butter - very light clutch pull and great modulation on corner entry.
Definitely my preferred setup for the Hypmo.
Aug 15th, 2008, 8:02 pm
Thanks, Folks!
Thanks, Folks!
Please keep the info and suggestions, etc. coming! I really appreciate it.
Mr. CorseMoto,
I really appreciate the picture, but could you also be a bit more specific regarding your set-up and perhaps provide some more detail... like where you got your clutch, which "lighter" springs, etc.???
Thanks!
Dallara
Aug 17th, 2008, 12:58 pm
<bump>
Aug 17th, 2008, 8:07 pm
Just mounted the EVR Slipper from Shift Tech it is a complete kit you need nothing extra it is first rate, looks great and works very very well. It is also much quieter. I have the DP slopper on my 1098 and it is not near the clutch this is................EVR baby
Black Carbon Diavel
848 EVO
Aug 22nd, 2008, 3:25 pm
Anyone else have suggestions, ideas, experienes, etc.???
Thanks!
Dallara
Aug 23rd, 2008, 6:02 am
Senior Moment
as long as you're going to put in a clutch, you might as well pop out the primary gear and have that lightened.
Nichols on the flywheel.
