Originally Posted by Quackzilla
...it seems that everything references CO% rather than AFR/Lamda.
I believe DukePilot posted somewhere a chart that converts between %CO and AF.
I use the VDSST with a Gastestor and Termi 2-1 ECU. Bear in mind one cannot adjust Fuel Trim on the stock ECU. Don't forget to also synchronize the throttle bodies, reset the TPS and, if needed (not likely), the idle set screws.
