Cored Exhaust?? - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Aug 13th, 2008, 3:31 pm   #1 (permalink)
kingsnake1650's Avatar
Cored Exhaust??
Looking for more noise, and want a quick fix till I decide what full system I want on my bike. Has anyone core the pipes on a hyper? how does it sound and does it throw the CPU out of what? If anyone has cored thier some directions or atleast some helpful hints might be nice.
Thanks
kingsnake1650 is offline   Reply With Quote
Old Aug 13th, 2008, 7:16 pm   #2 (permalink)
nwrob's Avatar
Thanks
Doesn't seem worth it, but hey...
It was SM171's fault!! @#*&!
nwrob is offline   Reply With Quote
Old Aug 13th, 2008, 8:16 pm   #3 (permalink)
well after reading that... nothing against goodwood but there are better tools that would make that job much easier. IE Plasma cutter rather than a drimmil and a jig saw.
I guess the real question is the A/F ratio. Who all has cut their air box? does it require a a power commander or DP ECU??
I am at 2800ft above sea level and we have and averge of 15% hummidity. Doesnt the HM run lean from the factory? how lean? will doing these mods push it to far with out adjusting the fueling? Im not really concerned about power for now. Just want a little more sound
Old Aug 14th, 2008, 1:33 am   #4 (permalink)
GHEZZI's Avatar
Interesting reading
Try www.moto-one.com.au/performance/#2v
These guys are in Melbourne Aust, at sea level so there are differences to your situation. They haven't done a Hyper either but their experience may shed some light.
Old Aug 14th, 2008, 11:01 am   #5 (permalink)
I sent and E-mail to Brad hopfully he can shed some light.... I got a PM from someone on the sight that has done the exhaust coring and the air box mod. He said his bike runs great... just barley on the lean side. but he is also at see level.
Will keep you guys posted.
Old Aug 14th, 2008, 9:27 pm   #6 (permalink)
ok I sent and e-mail to Brad at Moto one. Here is his responce.....
"jamie
many people would do what you describe and ride any without another thought to tuning. i don't think it will make that much difference, but it's a case of you either do something or don't. the problem with the later bikes is that doing something tends to be more involved and expensive than previously.
try it and see how it goes. you could dyno it and see how the mixture is as well as how it feels on the road. and you really need to find someone local to you that you trust who can do the required tuning bit for you - that's often the biggest issue.
Brad Black
Moto One Workshop
03 9568 0100
www.moto-one.com.au/performance/"
So I think I will just do it and see how it works out for me. I am a little hestitant because the closest Ducati shop would be AMS and they are about 5 hours away.
Old Aug 15th, 2008, 5:51 pm   #7 (permalink)
OK I went ahead and did it today. It was sort of a PITA but it sounds AWSEOME!!!
Basiclly here is how it went
#1 remove pipes. It pretty straight fwd take off. you will have to remove the license plate bracket and the side covers. then seperate the 2 cans
#2 drill out the rivets. They are stainless so go SLOW with the drill and use a good bit. just drill them untill the tops come off. Then use a blunt punch (like what you use to set a nail) and hammer the base of the rivet into the pipe. You will hear it drop out and it will leave the hole nice and clean. you could drill the rivets all the way out but that is REALLY tough and would probably eat up some bits.
#3 grind or cut the fake end thing off the can. It like there is this little raised piece with 3 tabs holding it on. I used a grinder and cut it at the weld.
#4 cut the real end off the can. For this I use a plasma a torch or cut off saw would work but plasma's are the best. You will also need to cut around the outlet hole as well. The the end will come off and you can see the inside of the exhaust can.
#5 Remove the small pipe that originally was welded to the exhaust tip. This is tough because its hard to get into the can to get it. I ended up using a metal chisel to free it up a little and a pipe wrench to twist it free.
#6 weld it all back together. It doenst have to be weled solid... just line it up and weld it enough that you know it is there. weld the fake end cap back on too. if you dont have a welder Im sure a local muffler shop would weld it up for a couple of bux
#7 put the aluminium caps back on and rivet them in place with 5/32 rivets. I used stainless that are hard on cheap rivet gun though. I think aluminum rivets would be fine.
#8 put the exhaust back on the bike... use loctite on the bolts!!!
#9 Listen to that sweet sweet Ducati roar.
This is how I went about doing it. the hole job probably took me 4 hours. Taking the exhaust off was the most time consuming part. I dont think you have to be a mechanical guru to pull this off...but you will need some tools to make it easy.
for my next job I amd thinking of sealing off the left muffler and figure out a way to make it a dummy with a removable end cap. So that I could use it for Storage maybe for a fuel bottle. Two Bothers did made a set up the the Honda VFR that was like that.
Old Aug 21st, 2008, 4:44 am   #8 (permalink)
MY45's Avatar
Full run down with pics
Standard Exhaust Shinanigans
MY45 is offline   Reply With Quote
Old Feb 5th, 2009, 8:39 pm   #9 (permalink)
sick50ford's Avatar
kingsnake or anyone with similar set up. how good did this look finished? sound stay tight but louder? any negative feedback? i have the racing ecu. thanks
Old Feb 5th, 2009, 8:53 pm   #10 (permalink)
It looked stock...with the exception of the exit hole in the pipe is bigger.
The sound was WAY better... not a ton louder but alot deeper and more full.
DP Race Kit Exhaust vs Strati Cored Exhaust ktm477 Superbikes 1 Oct 12th, 2006 3:02 pm
Cored stock Exhaust? Chapy Supersport 10 Sep 12th, 2006 9:00 pm
anyone gutted / cored a 999 termi can (full exhaust)? to make it louder? brian777 Superbikes 13 Sep 7th, 2006 10:14 am
Cored out stock exhaust teddy Superbikes 17 Mar 20th, 2006 12:59 am
Finally cored my exhaust. epx666 Superbikes 2 Feb 17th, 2006 2:12 pm
