14T DP vs AFM or other - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Aug 13th, 2008, 2:04 pm   #1 (permalink)
After reading a bunch of the different threads on gearing down I've decided to go with a 14t up front. My question to you guys is which is better: the DP or AFM or another aftermarket sprocket? Better meaning quality of the part vs cost.
For me it is not so much greater acceleration (it already sinks my eyeballs back in their sockets sufficiently) but hopefully better ride-ability in town in lower gears - less hurky-jerky when the bike isn't sure if it is idling, stalling, or going w/o murdering my clutch...
Of course I have to get it back from the shop for the infernal stalling first but this will go on right after.
Opinions?
Hypermofo
________________
08 Hypermotard
Hypermofo is offline   Reply With Quote
Old Aug 13th, 2008, 3:20 pm   #2 (permalink)
GMP
For now just get the 14t DP, see how you like it, and then when your set wears out get the AFAM carrier and 520 conversion in the same gearing or 15/44 if you think its too low.
You will need a GOOD 1/2" impact gun to break the countershaft nut loose and also need to remove the peg/shifter mount for room. With the peg mount removed all the force of the side stand will be to the motor case, not a good idea, just support the bike on another stand before you start.
Took me a half hour, if you don't have the tools especially the impact just tell the dealer to install it while its there.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Aug 13th, 2008, 3:20 pm   #3 (permalink)
wicky69's Avatar
Opinions?
I fitted a 14t for the same reasons... and to facilitate 2nd gear wheelies, if I'm honest.
But... I'm sorry to say that, while the wheelie part worked (at least, it's just my lack of skill that's the problem now), the 'hurky-jerky' didn't really get any better for me. Then again, I did make other changes at the same time, eg. slipper clutch.
As for the make of sprocket: I got an AFAM (520, lightened) one. The DP parts are just way overpriced in my opinion. Have you seen the price of their chains?
Cheers,
Mike
wicky69 is offline   Reply With Quote
Old Aug 13th, 2008, 8:41 pm   #4 (permalink)
the stock 2nd gear wheelies arent enough? try pulling up
08 HYM
77mopar is offline   Reply With Quote
14T Sprocket Installed today...quick question mdesmond Sport Classic 8 Aug 8th, 2008 4:10 pm
696 14T Ft Sprocket DP Part # FLROADKING Monster 2 Aug 8th, 2008 2:25 am
Northern California AFM rxrated Road Racing 5 May 28th, 2008 8:35 pm
14T Front sprocket MDMason HyperMotard 23 May 10th, 2008 3:23 am
