hyper broke down!!! - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.com
Old Aug 13th, 2008, 6:34 am   #1 (permalink)
Unhappy hyper broke down!!!
Hey guys my hyper broke down during a ride for no reason. The problem located somewhere within the clutch!
I was at a red light i step in 1st gear nice and then 2nd and thats it! it wouldnt accelerate and i could hear a strange noise wihtin the clutch! Something is broken!
Do you guys think that this problem may be caused due to the DP slipper clutch i use?
george_v is offline   Reply With Quote
Old Aug 13th, 2008, 7:23 am   #2 (permalink)
Caidly's Avatar
I doubt it. Sounds more like the internals of the tranny, or more likely the new 10mm wider fork stops.
if you need to know... ask...
Old Aug 13th, 2008, 12:25 pm   #3 (permalink)
georound's Avatar
Does your bike shift through the gears if you rock it back and forth? If it's in gear, does the rear wheel freewheel?
Old Aug 13th, 2008, 2:40 pm   #4 (permalink)
freezer16801's Avatar
if the lever is stuck in the down position, it sounds like your bike is stuck in 2nd. It has happened to a handful of us and ducati is aware of this problem.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Aug 13th, 2008, 3:42 pm   #5 (permalink)
What's the milage on your bike ? Is this problem happening at a certain milage or just random to people ?
F-
Ferrell75002 is offline   Reply With Quote
Old Aug 13th, 2008, 4:22 pm   #6 (permalink)
georound's Avatar
I guess the fix is a new spring. I've read that it can happen as early as the ride home from the dealer. This didn't sound like the same problem, unless it's stuck in a false neutral. That's why I was asking if it would go through the gears.
Old Aug 13th, 2008, 6:15 pm   #7 (permalink)
Yeash
This happened to me the other Monday morning. I was only 2 miles from home so I turned around and rode back home in 2nd.
The shifter would not budge.
I pulled into the driveway and it shifted.
I have ridden 100 miles since then and it's been fine.
Is this something that happens from time to time?
Warrantee issue?
Alpinist is offline   Reply With Quote
Old Aug 14th, 2008, 3:41 am   #8 (permalink)
check out this thread : Shift Lever Stuck
hossegor is offline   Reply With Quote
Anybody have (or had) a Multistrada? How did it compare to Hyper? josephvman HyperMotard 14 Jul 19th, 2008 6:58 pm
Hyper S... Termis and Cams breakdown HyperMotard 9 Jul 8th, 2008 7:38 pm
Multi vrs Hyper bromike666 Multistrada 31 May 28th, 2008 2:11 pm
what bikes did you own prior to the hyper? booger weldz HyperMotard 49 Mar 10th, 2008 1:15 am
Hyper on Motorweek!? MarksFriggin HyperMotard 16 Oct 16th, 2007 12:00 pm
